Quick question about suspension. I reinstalled some standard suspension into my R33 and i started to hear a solid "clunk" sometimes from the rear when driving along, and not nessesarely when going over bumps etc. Its slowly happening more and more and Im starting to get a little concerned.
Where exactly do you think the noise is coming from, or the reason for it? Im hoping to confirm its not something which will fail on me while driving. And yeah, I have coilovers, but gotta wait until they get imported to put them in.
thanks
when does this happen theres quite a few diffrent reasons that this could happen ?????
are you turning brakeing??
what else has changed on the car recently???
are you sure you put everything back together properly ???
small things like the papper or rubbers seals under camber tops can cause this ??
more info = more help
the clunking happens regularly, but at random times, not nessesarely while going straight/turning/accel/braking.
At that time I took off my coilovers and replaced with standard nissan stuff. I didnt change anything else with the suspension.
Im quite sure I put it all back properly. Its a simple enough process (still took all day though) and Im therefore sure everything was done up back as it should have been.
I cant remember if there were paper seals under the camber tops, there might have been, I just bought them and slapped them in. I dont see how that could be responsible for the kind of clunk im getting though (does it? it might?). I would expect a squeek issue for something like that.
My thoughts are that it could be either the shocks/struts I put in which are somehow stuffed or the ball joints for the rear sus or, less likely the Hycas ball joints. But I have no experience with sus gone bad, so Im hoping for experiences and advice from those who have.
The shocks themselves seemed in decent condition, no leaks and the plastic cover was complete and in good condition. I cant remember if it had the paper gaskets; i think so but not sure, it was about 3 months ago that I put them on. I also have a strut bar and the standard trunk bar.
Whats the purpose of the paper tops anyway?
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
