Hey guys,
I have a bmw e30 coupe, with a rb25 and 5 speed setup out of a r33. It has (from what ive been told by prev owner) gt30/76, upgraded injectors, fuel pump, 3 inch tbe, haltech platinum pro plug in. Was meant to be making 270rwkw, but that was on a dyno dynamics dyno, i did a run on a mainline dyno and made 240rwkw with very safe afrs, and a touch of wheelspin. (18psi)
I am having a huge misfire at about 3000rpm under load, if i baby the throttle on it doesnt misfire at all, i had heard the coilpacks are known for issues. So i have swapped in some yellowjacket coilpacks but with no difference.
I have fixed a few issues, the install was a bit shoddy. not impressed with the work done to be honest.
I dont know where it was tuned, i have the haltech ecu manager but honestly dont have much of an idea as to what i am doing lol.
it also doesnt run a afm or oxygen sensor but it was very safe on the dyno run so im not overly stressed about the tune.
Where would you recommend a retune in adelaide?
Any ideas on the misfire guys?
Cheers for any input!
https://www.sau.com.au/forums/topic/403641-e30-rb25-setup-issues/
  • Replies 41
so does it have a map and air temp sensor?
miss fire will generally be more erratic and not at a specific rpm.
When you say huge miss fire does it feel like it cuts out? misfires are generally less aggressive as it sounds with you
what psi is it at 3000rpm?
what turbine housing size? waste gate? boost control?
vct working?
has is always been like this since ownership or just recently?
need more info bout your car my friend
Edited by Candyman69
Doesn't run a maf sensor, doesn't run an oxygen sensor, it hasn't always been there, it's what I would call a misfire, fullpower, to nothing then full power, might do it twice and then its all good all the way to 7300,
It does seem to be getting worse, I will try plugs and see what happens.
Turbo I was told is a gt30/76, other than that I don't know. How can I check vct? It is all good if I ease into it.
I'll go for a squirt and have a go at data logging it later today so I know exactly what psi it's at
Haha yeah it 'looks' like there is a bit of room but I've run out of space in the tunnel so would be a massive job to move it back to get the cooler hidden
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
