R32 Gtr for sale in Melbourne.
177... KLM's
Regularly serviced
The good-
K&N performance filter
Aftermarket front mounted intercooler
Semi hard brake pads New 3.5" free flow mandiral bend exhaust system with 5" Kakimoto tip
Adjustable multi link with coil spring gas damper suspension
18" Marriot deep dish rims with 3" lip (some rust)
Aftermarket front sway bar
Nismo Group "A" side mirrors
Nismo Group "A" rear wing
Nismo Group "A" front bumper
Nismo Group "A" bonnet lip spolier
Tenon remote start / alarm system
Audio
Bosejia super tuner II 50Wx4 USB/SD-MMC Card/MP3/WMA tuner (cd not working, USB is fine)
7" TFT dash mounted LCD monitor (bracket needs replacing)
1000w boss 4 channel mosfet bridgeable amp
5000w powervox 2 channel mosfet bridgeable amplifier
response 2.0 farad capasitor
power acoustic explosion 3000W12" dual coil subs
2x blitz 80W tweeters
2x blitz 360W 6.5 mid components with bass detector blue LED
2x blitz 12dB cross overs with bass detector blue LED
2x explod 6x9 rear speakers (need replacing)
The bad-
paint work has stone chips / cracking
small amount of rust above rear passenger tyre (shown in second picture)
Front driver seat has tear/ rear bucket has small tear
Original GTR steering wheel is delaminating
Exhaust system was taken off for EPA test, replaced after test, now leaks at manifold (may just need retensioning?)
Front passenger brake squeels since new pads put on
Still drives great,but is time to move it on.
Contact:
Paul 0410319374
post-48987-0-78832500-1340920650_thumb.jpgpost-48987-0-70719200-1340920658_thumb.jpgpost-48987-0-14898800-1340920664_thumb.jpgpost-48987-0-51923500-1340920670_thumb.jpgpost-48987-0-80267200-1340920680_thumb.jpgpost-48987-0-28331400-1340920688_thumb.jpgpost-48987-0-93085900-1340920695_thumb.jpgpost-48987-0-99335900-1340920708_thumb.jpgpost-48987-0-61328000-1340920725_thumb.jpgpost-48987-0-46800700-1340920735_thumb.jpgpost-48987-0-51867700-1340920745_thumb.jpgpost-48987-0-75285000-1340920754_thumb.jpgpost-48987-0-29834900-1340920772_thumb.jpg
https://www.sau.com.au/forums/topic/403656-r32-gtr-for-sale-vic/
  • 4 weeks later...
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
