R34-CoNvIk Posted June 28, 2012 Share Posted June 28, 2012 We have a R34 GTT Mods: Link G4 Standard Turbo Waste spark set up 3" exhaust Intercooler Its in the shop, and both the mechanic and us are stumpd as... The compression in the cylinders is all good Turbo has been tested, there is no air leaks anywhere even with the turbo wastegate closed off it will still do 5psi Any clues on what is happening would be awesome Cheers R34-CoNvIk Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/ Share on other sites More sharing options...
Tommy Kaira RL Posted June 29, 2012 Share Posted June 29, 2012 I had a blocked cat that wouldn't let me get boost over 3psi. Its worth taking that out for a look. Mine was running 20psi when I went out and when I came home it was blocked. Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6422990 Share on other sites More sharing options...
Moodles2 Posted June 29, 2012 Share Posted June 29, 2012 Is the dump pipe a split design? It's possible the flap is stuck on the dump's divider (stuck half open for example). I assume you have some sort of manual boost controller or EBC? You might need to run a new vacuum hose straight from the boost controller (manual or EBC) to the wastegate, and/or a different boost source for it. Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6423163 Share on other sites More sharing options...
mad082 Posted June 30, 2012 Share Posted June 30, 2012 +1 for a possible blocked cat. a mates 33 i did a turbo upgrade on wouldn't go any higher than 12psi even with the hose to the wastegate removed. Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6423883 Share on other sites More sharing options...
R34-CoNvIk Posted June 30, 2012 Author Share Posted June 30, 2012 3'' all the way though and still the same.tested the turbo all good the motor has only done 80.000km.HELP HELP its been in the shop 4 six months we stumped Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6424236 Share on other sites More sharing options...
34GeeTeeTee Posted June 30, 2012 Share Posted June 30, 2012 3'' all the way though and still the same.tested the turbo all good the motor has only done 80.000km.HELP HELP its been in the shop 4 six months we stumped Have you dropped the cat like the guys have suggested? Checked for blockages etc? Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6424296 Share on other sites More sharing options...
R34-CoNvIk Posted July 1, 2012 Author Share Posted July 1, 2012 yes the cat been cut out.it sounds like it under load when you rev.the blowoff valve goes off early and it set hard its not leaking.timeing been set ova and ova diffrent tunes it must be something .f**k f**k this thing lucky its a skyline.HELP .....SOS... Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6424633 Share on other sites More sharing options...
Tommy Kaira RL Posted July 1, 2012 Share Posted July 1, 2012 How about you explain in detail from the beginning what you have tried and don't reply like a text message its hard to read between the lines. yes the cat been cut out.it sounds like it under load when you rev. <<What exactly are you trying to say. Are you just assuming the cat has been cut out because it sounds like it under load when you rev. You have said there is no leaks then you might have a blockage. What tests were done to the turbo? Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6424668 Share on other sites More sharing options...
PM-R33 Posted July 1, 2012 Share Posted July 1, 2012 Post up a dyno graph with a power and boost plot to make it easier to see what is going on. Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6424771 Share on other sites More sharing options...
mad082 Posted July 1, 2012 Share Posted July 1, 2012 Have you tried putting a boost gauge before the intercooler and one after it to see what sort of drop you are getting? May have a rag or something stuck in there Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6424858 Share on other sites More sharing options...
R34-CoNvIk Posted July 2, 2012 Author Share Posted July 2, 2012 Right, we have closed off the wastegate and still got only 5psi we have put 3" exhaust all the way through, we have got 5psi before and after the intercooler, we have retarded and advanced the timing, as well as setting up different O2 values we have checked that the turbo wheels arent loose we have checked the compression on all cylinders we have checked all the injectors, put a waste spark setup on it There is a link G4 storm installed we have tried running 20psi through the link and the engine just wont do it????? we have bypassed the intercooler, going straight from turbo to manifold TCS has been disconnected (would it help taking the whole unit off the throttle body?) Cat has been removed....... all the new electics have been checked over more than 5 times..... Runs hotter than usual when its idleing Have put electric fans on @ constant 92 degrees When engine is reving up in neutral, its as though its taking off in 1st gear, Sounds like its under load and has no grunt at all when test driven???????????????? Cam Angle Sensor has been replaced Just a few more questions.... Could it be that the timing belt has slipped a tooth on one of the cams? Could the crank angle sensor be playing up? Have the knock sensors got anything to do with this problem? To me it sounds like its an internal problem? Any feedback would help greatly Cheers R34-CoNvIk Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6425998 Share on other sites More sharing options...
mad082 Posted July 2, 2012 Share Posted July 2, 2012 it could be that the timing belt has jumped a tooth. i've seen some pretty weird stuff happen with cam timing that is out. a mate had a CA18 with a broken cam (so timing was variable, LOL). yo ucould get it to blow flames by pumping the accelerator at about 2000rpm. it was also a slug at times. sometimes it would drive fine, other times it felt like you had your foot hard on the brakes (this also resulted in it making full boost by about 1500rpm). Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6426695 Share on other sites More sharing options...
ricsvtr Posted July 3, 2012 Share Posted July 3, 2012 Pretty sure the stock wastegate spring is set to open at 5psi - the stock boost solenoid opens after a certain rpm to raise boost to 7psi. Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6427568 Share on other sites More sharing options...
ricsvtr Posted July 3, 2012 Share Posted July 3, 2012 sorry didnt read your post fully.... Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6427573 Share on other sites More sharing options...
NYTSKY Posted July 3, 2012 Share Posted July 3, 2012 92c at idle ib bloody hot. Did you even check base timing? Does it have aftermarket cam gears? Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6427582 Share on other sites More sharing options...
gotRICE? Posted July 4, 2012 Share Posted July 4, 2012 This may be a silly question, but do you have any sort of boost control? You say you have "run 20psi" through the link, but if there is no boost solenoid to talk to it wont do anything. One other thing, check that the auxiliary output for the solenoid is actually switched on. Iv done changes before, and forgot to save them, or loaded and stored old tunes that didnt have recent changes etc. If the solenoid is non existent, or the auxiliary output isnt configured correctly, then you will only be able to run 5psi. As thats what the stock actuator is rated at. Try this too, hit F12 while in PCLink with the car connected, it will bring up the runtime values. Find the auxiliary output you wired the boost control to and see if its switched on there. Its also possible it has an RPM lockout. Might need to give it a rev to activate too. Link to comment https://www.sau.com.au/forums/topic/403657-i-can-only-get-5psi-and-nothing-more-wtf/#findComment-6429285 Share on other sites More sharing options...
