It will be softer coming onto boost running just the actuator. Using a manual boost controller will see it come on a bit harder and gives you adjust ability
I honestly dont see why you don't just get one of those turbotech eBay boost controllers. Plenty of good reviews and its not expensive
Turbotech is crap from my experience. Go with the stronger actuator, you wont get defected for it (paint it black) and it will give you a much better outcome.
If you are good with your hands you will be able to make a bracket to suit, take some pictures if you get the Kinugawa as i'm sure more people will be heading down this path soon. ;)
Turbotech is crap from my experience. ;)
what was your dramas with them? i did back to backs on all the boost tees and the turbotech works the best hands down, with gfb in last..
I had the original turbotech and it seemed OK...
Perhaps on rb's and with hd actuators fitted already? I found the bleed hole was way too big. They are nothing on a HD actuator though, especially if the manifold pressure is getting up there, as it just blows the puck open.
The Turbosmart one seemed a little better to me, (smaller bleed hole) but a good electronic boost controller gave a noticeable gain. Personally I would run both a HD actuator and a good EBC.
Here is the info on the actuator. Just for anyones info if they are looking to do the same. I have ordered mine.
http://www.ebay.com.au/itm/280892958327?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Yep, and use new hose. Take some pics for us on the fitment and quality, I was interested in these actuators myself as I want to modify it for a push and pull setup.
Make sure you check it doesn't overboost before you get on it hard.
