There's a steep driveway at my Mum's place which would abrade low lips like nobody's business at the bottom concave section.
Then I installed a rubber speed hump set. It took half an hour to get the positioning just right & then the masonry bolts went in.
The lower lip only faintly brushes the rubber hump now :)
https://www.sau.com.au/forums/topic/403665-steep-driveway/#findComment-6422140
Did the dodgy and used a plank of wood and some bricks... looks so shabby
Will look @ investing in some of those rubber speed humps.... I have the same problem with the curve @ the top of the driveway.
Have to reverse up to get out too! Skidding all over the place with the semi slicks ....0.o
https://www.sau.com.au/forums/topic/403665-steep-driveway/#findComment-6422456
I made a custom lip that was 20mm shorter than standard. Extreme approach but I have the driveway from hell (but ain't moving cause cost us just about everything we owned to get into this place).
Oh and have the wood and bricks too to get out of the garage to the incline on the driveway (goes up then down onto the street).
https://www.sau.com.au/forums/topic/403665-steep-driveway/#findComment-6423403
Pick and shovel with hard work or a bobcat and cash.
I made a driveway, carport, and level paved area all by hand.
It helps to have construction experience so you get the drainage and retaining walls right.
Second hand pavers and my own ute made it cheap.
My back says i should have paid for a bobcat.
>_<
https://www.sau.com.au/forums/topic/403665-steep-driveway/#findComment-6425277
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
    • Actually No, I’m not as intuitive as u
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
