Hi all, going to upgrade my standard 33 s1 rb25 fuel system. looking at a walbro 255, tomei 740cc side feeds and a turbo smart regulator. from what i can gather those are all close to direct fit replacements. is it that easy? are there any major issues i will come across that im sure someone else would have already found? any help would be great
https://www.sau.com.au/forums/topic/403666-rb25-fuel-system-upgrade/
Do as was mentioned above, pump (hard wired for alternator voltage) and injectors.
You probably won't need 740's though, unless you are thinking this turbo isn't going to be the last/biggest one you get
In saying that Mitch i made the mistake of buying 550's and then had to buy 1000's later for E85, bigger isnt always a bad thing and the prices are similar, as long as they are decent injectors go nuts :)
By all means get the bigger injectors if planning to go e85 or get a bigger turbo down the track, as there is no difference in price really. But if intending to leave it at the highflow on 98 then 555's will do the job as well.
In retrospect i would have gone 740's as well because you get the power bug once you start!
yeah get good quality big cc injectors straight up 740s will cover you for alot of power...just saves headaches should you wish to upgrade later....
get big cc cheapo injectors now and you risk a crappy idle and bad fuel economy...
can we get a list of possible injectors for high power applications, so far i have deatchworks 1000cc but not sure bout idle and quality and fitment, power enterprise but have found they can have idle issues and be lazy? ID or xspurt 1000's but ill need to mess round with a top feed rail which is not encouraging, and then nismo's which are expensive,
just want to know what is the choice injector. and do it first time right...
Dude, it's a 25.... So many options!!! I went HKS rail and am happy az....
When it comes to advice, Guilt_Toy and Ash are as good as it gets, don't ignore it :)
you can xspurts or IDs in with the stock plenum on a 33 ,fuel rail is only 100$ regs arent too expensive either, fuel hose is cheap also and you will need a pressure gauge which is 20$..
I got.xspurts in 750cc in 40mm, which are shorter than IDs which are 48mm, so makes for an easier fit,, I think both will fit, I'm yet too see IDs with stock plenum but it could be done..
.Injector will cost you 6-700$ and they are amongst the best..Ask anyone and they will tell you they are great to tune, great at idle and great for economy too...
heres mine fitted up, I got them in without removing the plenum, tricky but possible
fuel rail
http://goodiesdirect...&product_id=405
Do it once, do it right... :thumbsup:
fuel rail
Thanks guys , just made my decision easy :thumbsup:
Just one last question, i rang EFI today and also horsepower solutions, 2 recommended on here about ethanol, got two different bits of advice
EFI said a 400lph walbro will be an absolute minimum for 300kw and need 800cc minimum injectors
Horsepower solutions says 2X 044 externals and was very sure about it, said ill use almost double the 98 i use when flat out
so the 2X 044's is extreme dont you think? and said ill make 320kw
now im thinking more that EFI know what there on about, but if a 400lph walbro is minimum what more can i do??
if the gtx3076 is to get upto 22psi without restriction, im thinking a walbro 400lph and Xspurt 1000's, should i expect 340kw's here?????
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
