scotty nm35 Posted September 3, 2012 Share Posted September 3, 2012 I have one on the wreck, and the unit on my car may be for sale soon... Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6516217 Share on other sites More sharing options...
zei20l Posted September 4, 2012 Share Posted September 4, 2012 take a number, buddy! Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6517576 Share on other sites More sharing options...
Daleo Posted September 4, 2012 Share Posted September 4, 2012 I have one on the wreck, and the unit on my car may be for sale soon... Oh really? Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6517794 Share on other sites More sharing options...
scotty nm35 Posted September 4, 2012 Share Posted September 4, 2012 6 speed conversion buddy. Should have done it last time the box melted. Its a shame loosing the AWD but the weight saving alone will make it all worth while I think. I'm so over the auto, why won't it just shift when I tell it to... Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6518443 Share on other sites More sharing options...
Commsman Posted September 4, 2012 Share Posted September 4, 2012 I'm so over the auto, why won't it just shift when I tell it to... A= BFS - numbers in map are too low. Low numbers = slow shifts; but don't know how you'd go about changing that since your injectors are controlled by F-con, correct?. 6 speed sounds like the best solution for you though. Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6518481 Share on other sites More sharing options...
scotty nm35 Posted September 4, 2012 Share Posted September 4, 2012 Shifts are fast but the time it takes to decide is a joke. Usually it just bounces off the 7500 limiter on wot, not good at this power. Plus the gearbox won't drop in to a lower gear until the shaft speed has slowed enough, it's horrible changing gears in corners... Added to the usual crappy reaction times, the box can only do 2 laps of PI without overheating, and causing weird transmission faults. Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6518510 Share on other sites More sharing options...
PN-Mad Posted September 4, 2012 Share Posted September 4, 2012 Come for a spin in mine on the weekend. I'll show you what the difference is like with the gearbox Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6518550 Share on other sites More sharing options...
scotty nm35 Posted September 4, 2012 Share Posted September 4, 2012 Not much point if it cant hold the power, even if I could fit the PM35 box. I'm not going down the 33/34 GTR box either, a whole can of worms. As the easiest, most logical and cheapest option I decided on the 350Z box. At least I can swap back if I ever need to... But I will be leaving the console handbrake. Rather than clutter this Attessa thread I will start another to discuss it. Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6518566 Share on other sites More sharing options...
PN-Mad Posted September 4, 2012 Share Posted September 4, 2012 Ah, not suggesting you go a PM box - too much headache. I'm for rwd manual all the way. Just want to show you the difference in shift decisiveness. New thread is good idea. Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6518570 Share on other sites More sharing options...
Sage222 Posted September 27, 2012 Author Share Posted September 27, 2012 so i took my baby to kewish (thanks scott). Error came up as 4WD Actuator Relay C1205. Sounds relatively inexpensive (i hope). Anyone done one of these? Advise on where it is and part number would be appreciated. Thanks gents. Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6552974 Share on other sites More sharing options...
Mr 20Valve Posted September 27, 2012 Share Posted September 27, 2012 The attessa relay is bolted to the radiator support, just underneath the airbox Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6553171 Share on other sites More sharing options...
pomnz Posted September 27, 2012 Share Posted September 27, 2012 Go to page 20 in the attachment, in the picture marked A the smaller item on the left labeled "E-TS アクチュエーターリレ" is the E-TS actuator relay. It's basically just beside the 4wd ecu, below the attesa fluid reservoir which is all in the boot wall behind the storage thingo on the drivers side. I Google translate. TF - Transfer.pdf Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6553450 Share on other sites More sharing options...
Brick Posted September 27, 2012 Share Posted September 27, 2012 When mine was scanned it comes up saying pressure switch. Would this be the same problem? if not what is it that needs to be replaced? Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6553521 Share on other sites More sharing options...
Sage222 Posted September 27, 2012 Author Share Posted September 27, 2012 pomnz and 20valve you guys are awesome. (and so is pretty much everyone on this forum). cheers Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6553621 Share on other sites More sharing options...
pomnz Posted September 27, 2012 Share Posted September 27, 2012 When mine was scanned it comes up saying pressure switch. Would this be the same problem? if not what is it that needs to be replaced? What code did u get? Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6553699 Share on other sites More sharing options...
Brick Posted September 27, 2012 Share Posted September 27, 2012 What code did u get? Not sure actually. Was scanned by my mechanic and he said it came up as the pressure switch but had no idea what it was. Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6554160 Share on other sites More sharing options...
pomnz Posted September 28, 2012 Share Posted September 28, 2012 Hmm not really clear, if you look in the attachment for pressure switch 圧力SW or 圧力スイッチ There are a few references but it's more about testing the functionality rather than where it is located. Try and find out the code and that will probably help otherwise if you have a multimeter and know what you are doing there are a few voltage and continuity tests you could do, let me know if you need more help. There is also this thread http://www.skylinesaustralia.com/forums/topic/402973-m35-attesa-ets-pressure-switch-problems/ What symptoms are you having? Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6555428 Share on other sites More sharing options...
Brick Posted September 29, 2012 Share Posted September 29, 2012 Hmm not really clear, if you look in the attachment for pressure switch 圧力SW or 圧力スイッチ There are a few references but it's more about testing the functionality rather than where it is located. Try and find out the code and that will probably help otherwise if you have a multimeter and know what you are doing there are a few voltage and continuity tests you could do, let me know if you need more help. There is also this thread http://www.skylinesa...witch-problems/ What symptoms are you having? My prob sounds very similar to that post except i'm not getting the pump chirping. Also when my light comes on i loose 4wd all together(which is fun in the wet haha) i would say 90% of the time its ok, and seems very spiratic when it fails, just seems to fail at any random time. Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6556245 Share on other sites More sharing options...
pomnz Posted September 30, 2012 Share Posted September 30, 2012 You could try getting your battery tested I know that these cars seem to start acting strange when the battery starts to go. Otherwise I would try the multimeter tests mentioned in the service manual. Link to comment https://www.sau.com.au/forums/topic/403668-4wd-light-now-permanently-on/page/2/#findComment-6557119 Share on other sites More sharing options...
