200sx S14 /S15 parts.
all parts can be picked up from Taylorslakes - Melbourne. Or can post all parts Australia wide excluding the exhaust at buyers expense australia wide. Contact me for a postage price.
Call or sms me on 0422756270 if interested. Cheers
1. Stock S14 Sr20det Turboback Full Exhaust system removed from a Australian delivered s14a.
-will suit both Series 1 & series 2. The whole system is in excellent condition and has no damage.
Ideal for clearing defects or returning your car back to standard.
Price: $300
2. Stock 200sx S14/S15 Bov & All The Plumback Piping.
in very good condition as pictured with all the piping needed toreturn your car back to standard.
Price: $180
3. 200sx s14/s15 sr20det Stock Airbox & Snorkel
Great for staying legal/ clearing defects/rwc or just changing it back from a Heat sucking pod filter.
These handle over 250 rwkw .Comes complete with a panel filter, ready to bolt on.
Price: $250
4. Stock 200sx s14 Turbo Exhaust manifold.
Standard S14 SR20DET cast turbo manifold with the port to connect up EGR.
Comes complete with new tappered nuts and genuine nissan turbo gasket.
These dont crack unlike the aftermarket manifolds.In very good condition, these still flow any easy 250 rwkw.
Price: $60
5. Stock 200sx S14/ S15 T28 Turbo Intake Snout
in excellent condition,
Comes with with a gasket. ideal for t28 turbo conversions on s13's.
Price: $80
6. Stock 200sx S14 / S15 T28 Turbo outlet elbow with 3 bolts.
in very good condition, to suit the stock T28 Turbo's both bushbearing and ballbearing.
comes complete with the 3 bolts and the gasket.
Price: $70
7. 1x Stock 200sx s14/ s15 Rear Rotor
This rotor will be good for someone that has a bad rotor & doesn't want to change all of them.
came of a S15 but iv been told s14/s15 are the same.
Price: $20
8. 1x Stock 200sx s14/ s15 Front Rotor
Price: $25
9.S14 rear boot spare wheel cover
Price: $10
10. Stock 200sx S15 Sr20det 6 speed clutch kit
S15 6 speed stock clutch disc , pressure plate ,9 bolts & bearing assembly
Car had 80,000km on the clock and was a Australian delived. Removed due to upgrade to a heavy duty Clutch.
Ideal for returning back to stock or if you have a bad clutch
Price: $70
Update of parts that are sold.
5. Stock 200sx S14/ S15 T28 Turbo Intake Snout = SOLD
7. 1x Stock 200sx s14/ s15 Rear Rotor = SOLD
8. 1x Stock 200sx s14/ s15 Front Rotor = SOLD
9.S14 rear boot spare wheel cover = SOLD..
Rest still available guys
  • 2 months later...
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
    • That's the one I have in my R32. There isn't a bigger battery that will fit an R32.
    • Not sure what you mean haha. That one doesn't fit mine but when I get sick of my one I'll get a standard one. I just gotta find a way to make it fit cause some shit is in the way.
    • https://www.supercheapauto.com.au/p/century-century-ultra-hi-performance-4wd-battery-ns70x-mf/602477.html MF for Muthaf*kka
