Can anyone help?
I just done the timing belt on my r33 rb25 ive done plenty of them and have never had this problem
I have fuel( fuel pressure, injector pulse, check all fuses), and ive also got spark( tried 3 sets of spark plugs, changed coils) and its still not starting
When i crank it, it doesnt start then i check the plugs again its fouled up
Dry the cylinders dry the spark plugs( or change them)
Try it again still doesnt start
Take the plugs out again fouled again
Take out fuel pump fuse disconnect injectors, still doesnt fire up even though theres fuel in the cylindeds
Disconnect cas still doesnt fire up
Reconnect cas still doesnt fire up
Recheck spark strenght, has plenty
It did start once when it was stripped down to the timing belt with everything connected, THEN ITS FIRED UP with a big puff of smoke then shut it down coz the timing belt was about to fall off, thinking it was fixed i reassembled
After assembling it didnt start, back to square one
Timing marks are spot on
Anyone have the same issue?
There are no vaccum leaks even though it should still start.
At this time its doing my head in bad
Have i misssed something?
Why is it flooding when ive got spark?
Also has a new temp sensor
Anyone help?
Correct Fuel, Spark, Oxygen = Run.
To overcome flooding keep foot flat on accelorator
Signal to spark at the right time was my only other guess.
Some of the Pro's on here will chime in shortly.
ive tried foot flat on the accelorator so many times ive flattened 2 drycell batteries :(
the signal should be right unless ive got a crook cam angel sensor?
damit, maybe ill try check injector pulse and spark at the same time and see what i can get
did you mark cas before you took it off so u can align when you reinstall it? when you say you striped it down then started it you would of taken of the cas to get cam cover off. my 2 cents is you may have put it on out of align hence the reason why when you started it the timing was out causing the big puff off smoke and belt nearly coming off as the belt should be rotating smoothly unless you touched the tensioner.
  • 9 years later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
