hi im doin a RB 25/30 specs include :
spool RB30DET (DOHC) Rebuild Kit CP 9:1 , RB head oil drain kit, Camtech 268/272 cams , RB25det head , RB20 covers, oil pump spool, crank collar, turbo manifold 6booost,
RB26dett plenum, HTA GT3586R turbo , water pump N1, R34 RB25det 5 speed gearbox
some pics :
RB30 as i got it
RB25det head as i got it
RB25det head sittin on the RB30 block with the RB20 covers and with a modiffied KKK turbo just for looks!
will add more pics as i go
CHEERS Oscar
Edited by MRHD66
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/
  • Replies 43
Posted Images
  On 29/06/2012 at 10:48 AM, Mitcho_7 said:
How is the rb26 plenum going onto the rb25 head? Pretty sure they aren't compatible without a shite tonne of modifications.
Also, you should have put this in the build section!
power tune do a manifold adapter kit that I will be using
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423063
  On 29/06/2012 at 1:28 PM, MRHD66 said:
how so mate
The water galleries are offset from one another so the plates need to mismatch to create an angle. You cannot use a gasket in between the two halves as it will block the outer one
They may be ok but from personal experience they are a complete f**k around to seal properly. Most people just use a tonne of silicon but that can block the water gallery and present its own problems
They may have changed the design since I saw the last one though so put up some pics once you get it
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423240
  On 29/06/2012 at 2:09 PM, MRHD66 said:
how much f#cking around Is gettin VCT to work on a RB26 head
For me.....none at all.
I'm not suggesting you go RB26 head but there are no gains by going RB26 plenum and throttles. In fact, your tuner is going to have an extremely hard time making it run nicely. You have essentially lengthened the intake runner by another inch or more which creates all kinds of problems with air bouncing back from the valve head and transient throttle at lower revs.
You are definitely better off with a Greddy or similar.
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423271
how much it cost to make RB26vct and do u use a RB25neo intake cam? I know it's not just cam too Edited by MRHD66
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423277
It's about $2500 with the head off.
No we designed our own custom camshafts. It's also important to consider valve clearance so not something I would recommend attempting at home
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423279
yeh mate I will get all that done when I get the VCT oil feed welded up
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423368
