hi im doin a RB 25/30 specs include :
spool RB30DET (DOHC) Rebuild Kit CP 9:1 , RB head oil drain kit, Camtech 268/272 cams , RB25det head , RB20 covers, oil pump spool, crank collar, turbo manifold 6booost,
RB26dett plenum, HTA GT3586R turbo , water pump N1, R34 RB25det 5 speed gearbox
some pics :
RB30 as i got it
RB25det head as i got it
RB25det head sittin on the RB30 block with the RB20 covers and with a modiffied KKK turbo just for looks!
will add more pics as i go
CHEERS Oscar
Edited by MRHD66
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/
  • Replies 43
Posted Images
How is the rb26 plenum going onto the rb25 head? Pretty sure they aren't compatible without a shite tonne of modifications.
Also, you should have put this in the build section!
power tune do a manifold adapter kit that I will be using
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423063
how so mate
The water galleries are offset from one another so the plates need to mismatch to create an angle. You cannot use a gasket in between the two halves as it will block the outer one
They may be ok but from personal experience they are a complete f**k around to seal properly. Most people just use a tonne of silicon but that can block the water gallery and present its own problems
They may have changed the design since I saw the last one though so put up some pics once you get it
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423240
how much f#cking around Is gettin VCT to work on a RB26 head
For me.....none at all.
I'm not suggesting you go RB26 head but there are no gains by going RB26 plenum and throttles. In fact, your tuner is going to have an extremely hard time making it run nicely. You have essentially lengthened the intake runner by another inch or more which creates all kinds of problems with air bouncing back from the valve head and transient throttle at lower revs.
You are definitely better off with a Greddy or similar.
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423271
how much it cost to make RB26vct and do u use a RB25neo intake cam? I know it's not just cam too Edited by MRHD66
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423277
It's about $2500 with the head off.
No we designed our own custom camshafts. It's also important to consider valve clearance so not something I would recommend attempting at home
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423279
yeh mate I will get all that done when I get the VCT oil feed welded up
https://www.sau.com.au/forums/topic/403700-my-rb2530-build/#findComment-6423368
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
