this is where my friends idea of having a headunit with a slot for the ipod instead of cassette comes into play...basically...u have a face plate that can flip down allowing u to plug ur ipod directly into the car...powered by car and controlled by faceplate...i know it can be dun...just need funding to develop it...and agreements...and the rest... btw.. patent pending :headspin:
funky you are da man!! :):D:(
deleted the song and it carried on copying the rest straight away... yayyy!!! :):D
Jimbo - lol at that thread "it'll be a long time before Apple ever makes a 40gig version" :)
nice effort on the install though...looks good in the holder thingy, mine's just sitting on the passenger seat heh
thanks for the links too!!! will check em out..
FriniK, great idea!
luke,
if you can find one look for a XA107. that is sony's aux in box for ANY sony product
that has CD controls.
i have the itrip and its good sometimes not so good other times, but on sony head units with cd changer control can the rca inputs for the changer be used on there own or do they require the bus input aswell (the fatter multi pin cable that controls the changer)
Sorry guys, totally forgot, pics will be taken tomorrow ...
As for you Mish, did I say this ??? "it'll be a long time before Apple ever makes a 40gig version"  :Oops:
Naa it was in that thread you posted from the US... the thread was from back in 2001 or 02 or something ;)
MUST get a car charger now, I've been ok driving around town, but will be driving longer this weekend (Putty Rd cruise) so i'll need it charged all day..
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
