So my car was missing under boost...I tried second hand yellowjackets and new plugs at 0.8... Still misses...
Then I do a turbo upgrade with pretty much everything new.. Both manifolds, injectors PFC fuel pump etc.... Still misses...
Today I went and bought new splitfires and put em in...miss got worse.... Now it's like really loud backfiring... Different to before.
Has anyone got any ideas to help me solve this problem.
https://www.sau.com.au/forums/topic/403712-misfire-from-hell/
Youve added a shit load of stuff to the equation now....should have sorted it before the upgrade, but still check CAS and make sure the blue plug on the ecu is in evenly, pressing in the ends and not over tightening the 10mm bolt, And I assume u changed the afm to Z32?
When you say backfire, on accel or decel?
Yeah it's missing on accel and sounds almost like a rev limiter with lots of little backfires..
Yeah it's a z32 afm and Toshi tuned it, we did what we could but we stopped when it was missing and I was going to go back and finish the tune once it's fixed.
Try gapping down your plugs to 0.6-0.65. I just did that and sorted my cutting problem at 0.8 Bar. Now good all the way to 1.4 Bar. I think my coils are loosing power so confirms that it is spark related.
Running that gap now with no probs at all, until the shop warms up to re-mount my coils (I run bosch coil set-up).
Dont think its actually the coils..For reference my splitfires had enough juice to run a gtx30 @20psi with wmi and 1.1mm gap
Sounds like an electrical gremlin....As said before check coil pack loom, ignitor if you have one, also make sure all earthing on the engine and batt terminals are clean and tight and again CAS
What plugs you running?
So if you get mad backfiring an high in the rev range it could be leaning out coz of the pump?
Definitely, mine did the same thing today on the dyno, changed coils, gapped plugs, no change. Ended up being one of the pos Walbro 342's not pumping properly. It seems they need to be fully submerged to operate at maximum flow, unless its just faulty... I was hoping the deatschwerks didn't have the same design flaw as this fault was occurring at 1/3 tank.
    • Ah yeah I forget we aren't talking about an RB.
    • Fellow ADHDer to fellow ADHDer; Don't chase that paint perfection. Paint the bumpers, and put them on.  Leave the respray for another day. Plus, no one is going to see those old areas above. Any spots of surface rust, give them a clean up, prime, then hit with a white paint just to protect them from rusting. Again, no one can see it.   #Mine hasn't been on the road since 2011 cause ADHD... I've slowly learned not to keep f**king with shit if I don't need to...
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
