Would be awesome if something like this was done in OZ. Get all the car clubs involved.
http://www.ppcmag.co.uk/999-challenge.html
Would have to push the budget up a bit seeing as you couldnt get a roadworthy 328i etc for $1500 thou!!!!!
https://www.sau.com.au/forums/topic/403719-ppc-%C2%A3999-challenge/
Once in the 80s whilst a lawyer was spending a sojourn in Fiji, he was informed by his wife that the SL500 he wanted to sell, went for a hundred.
He, with his mistress by his side asked, "You mean $100,000 don't you?
His wife, a true woman scorned, replied matter of factly, "No, one hundred dollars" and then hung up.
Such a car would have qualified would it not?
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
