Well - don't get me wrong. I am very very happy to be told its nothing to do with it and find another reason for it.
As I said above, Ross is a good bloke to deal with, its good to buy Aussie, RIPS uses them too - and I still do have mine - so I am all for it NOT being anything to do with the balancer.
But when Piggaz started throwing belts and so did I, especially when I wasn't before hand - it raised alarm bells. Now ABR33.
So I felt it was worth mentioning - just in case. Lets hope we can find the real reason though.
Yea for sure mate,defintaly worth the mention, and i can imagine its rather annoying that the blet keeps getting thrown. Hopefully you can sort the problem soon and report back with exactly why its happening (ross balancer or not)
How much power are you making by the way?
in the mean time you should get one of those idlers for the belt, not too expensive i imagine and fairly easy to fit.
about ur timing belt slipping... that is very strange
But can anyone explain why i was doing flat out runs down an airstrip for 30 mins, and drifting around each turning end, and after doing the same thing after doing it 20 times already it comes off? done nothing different.
One thing I can say is the belt is quite old and shitty, could it be poor strength belts allowing stretch?
Has anyone thrown a gates racing belt? seem to be tougher..
yeah got the idler kit Joey - it did help - how could it not - but we noticed the belt still tried to walk up the back of the damper. Plus I want to know why my ATI ran without an idler and never had the issue. Remember this was the ONLY change. And hence why I was suss about it. As Ross pointed out though, RB26 Power Steering pumps often seem to be a little on the piss, hence we went to some effort to replace the bracket - face it and line it all up with a laser. Fat lot of good that did me though.. I am almost wondering if something has happened to the crank nose during changing them or something - makes no sense.
My car is only a baby in RB30 terms mate. 20psi - 350rwkw. Spins too 7200rpm - soft limiter courtesy Motec. Plus I drive like a pussy according to Gav. So I'm not bouncing off a 9krpm limiter or anything.
Frustrating doing power steering belts and then burning the crap out of yourself changing them between runs at an event. And one of them coming off decided to tear into my Spal Thermo wiring... grrrr...
What issues do people have with stock gtr ballancers that makes them change to ross?
Nissan would have spent alot of time/money designing these to work reliably on their engines, gtr stock rev limit is over 8000rpm.
Ive never had or seen a power steer belt spit off using stock ballancer.
They get worn out over time and I imagine Nissan charge a mint to buy another one.. Other wise yea they are probably the best one you can buy
(Quote R32 TT )
Can confirm, drives like a pussy :rofl2:
Don't think its the same issue ( but I'll put it out there ), I've spat a couple of P/S belts with an ATI balancer, but only at 8500rpm and over 200kph, think there is enough flex in the clutch fan to just clip the belt..
Not the same issue as you Matt, obviously as you have electric/thermos, from memory.. but could be worth looking at for others.
(Quote R32 TT )
This is interesting, my fan tips have tiny tiny rub marks on them. I was going well in excess of 200km/h too. Not sure if that done it though I think it came off when i was in second though...
the factory fan flexes that much....?? so your was mainly due to the RPM ?
can't be sure on either case.. there was black marks on the fan but don't know if that was the cause or the result of the belt shredding? but the fan does have quite a bit of flex ?
and both times its happened to me was at the track or an event at over 8000rpm in 4th, so 220kph+ ..?
when its not spinning, the fan tips are only about 10mm from the P/S belt.. ?? but I've only done 2 belts in about 4 years so I don't know that this is related to the Ross balancer issue ( if there is one )
Torque figures above look right but I'd have to check my book. GTR would be tighter due to the metric superfine thread it uses (18x1.5) and the fact it's an 18mm bolt instead of a 16mm bolt in the 'lesser' models.
Remember boys and girls, it's all about correct tension, not lots of tension.
That 18mm bolt is definitely doing to need that much torque to apply the correct stretch to give it the exact preload it needs to never come off.
I've seen too many come loose recently....but come to think of it....all GTRs
Answering a question above about why replace the stock balancer - It's simple. Because they are shit
When they were brand new they were awesome. 20 years later.....shit
If you could pick only 3 things to modify in the engine of a GTR to make it near bulletproof at 600-800hp it's : 1. Rod bolts 2. Billet oil pump gear 3. Good aftermarket harmonic balancer
We have proven it many many times. Although given the choice, everyone knows my decision on stock rods
So the question on everyones lips (or mine) is what exactly makes them shit?
I can understand that newer designs/materials etc could make a better one - hence why I bought an ATI in the first place, but I am interested in why you say that - how does one 'measure' how well one damper is compared to another without some pretty special equipment?
ie something in your experience must have lead you to this?
(Quote R32 TT )
...you know.... that hurts a little. I brought it on myself, but still.. where's the love.
0
my mechanic just got me a new r34 balancer through nissan for just over 400 buks... Cheaper then aftermarket
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
