We did a similar thing on our race car. we run the 1000hp ati. We use the autronic cas disc for TDC reference. Except we attached the trigger wheel to the front side of the timing gear and the sensor bolts off the oil pump. It all ends up being hidden behind the damper.
Just did a full build on a RB26.
Tomei 2.8 kit etc.
Ross dampener with crank trigger wheel and power steering 20% underdrive
All items were balanced and crank, then ross dampener, crank gear, then the flywheel and housing, were balanced on the balancing machine.
Currently I'm on the 4th powersteering belt, even with 20% underdrive on the power steering.
And have spat 1 aircon belt when the power steering belt came off the 4th time.
It's nearly killed, or written off the car twice due to suddenly loosing power steering when you need it most!!...
So, what I have experienced is harmonics from the crank, and the dampener is not doing it's job.
I get very noticeable vibration at 6500RPM (free reving, and holding at that RPM point as well as driving).
And some vibration between 7000-8000RPM. Even took the car to an experienced engine builder/rebuilder and showed him, and he agreed that the dampener could be faulty as it is not suficiently reducing the crank twist/harmonics.
As the inline 6 configuration has great 1st order and 2nd order harmonics, but inherently bad at 3rd order harmonics, having an effective dampener is extremely important. More relevant as we see RB's hitting over 6-7-8000RPM in their normal factory rev range!
I'm pretty sure mine is faulty, and have ordered a brand new standard balancer to see if the problem really is the dampener.
If I leave it as is it will:
1.keep throwing belts at high rpm
2.cause other damage to engine components such as the block(cracking from harmonic vibrations),
flywheel bolts maybe rattling loose,
and oil pump damage/failure.
I'll post here again once I have changed the dampener :/
Did you say you 'balanced' the Ross Damper? I don't think you should have to - it should be balanced from factory.
Also - if you can feel very noticeable vibration - even free revving, then I wonder if you haven't got something more serious going on.
FWIW, I couldn't 'feel' anything wrong with my engine - it just kept blowing power steering belts off (and now the cambelt)
Sure will be interesting though if a stock balancer fixes it.
Yeah your not meant to balance ROSS balancers. They are balanced from factory.
If you replace it with an OEM balancer, what are you going to be about the lacking trigger disc on the OEM balancer?
Mine just didnt line up right, about 5mm out from balancer to power steering pulley, slotted out the power steering bracket 5mm and its fine.
I had everything balanced but they said there is no need to do the balancer, never had a vibration at all.
Though I only rev to 7200 and the limit is set at 7500, but it does rev up real fast once it gets to 4500.
2.cause other damage to engine components such as the block(cranking from harmonic vibrations),
Very interested to see if the stock balancer fixes the vibration issue...
Hi years ago when i used to play with v8 engines if you had a lightened flywheel and used a large hi po balancer on the front of the engine it would occasionaly spit belts off this was mainly on small journal engines when changed to a lighter one didnt spit belts anymore.I put it down to the rpm and harmonics from the drive train.
Maybe the same is happening here ?????
  • 1 month later...
+1 my ross tuff bound balancer didn't align with the power steering pump... however since I still hold the twin turbo set up... we were unable to get to the power steering bracket... We opted for taking out the power steering pump and sanding part of the rear to allow the pump to be pushed back further... It fixed my issue, I have given the car a bit of a hard time since doing so to test it and haven't thrown or eaten a belt since.
I'm sure most of you know but I didn't know until Ross told me that the power steer drive pully offset on the balancer is different RB26 vs RB25 and RB30 .
So obviously if you used the RB26 version on a 25 or 30 the pump has to move forward to line up . Likewise if you put the 25 version on a 26 the pumps own pulley will be too far forward .
A .
A few of you have asked why I got the Ross balancer balanced. I went and got it straight from him at his shop and he assembled all the pieces from his parts rack.
He did not balance it for me as I said I'd get it done at engine reco's. He just uses a wheel balance machine anyways...
So I changed to a brand new stock balancer and yep, it's as good as new. no more harmonics or thrown belts.
Ross one is getting sent back to find out what happened to the dampener, whether it has de-lammed or something else.
Also pulled trigger setup off for now too.
I'm just happy it's smooth again!
wow. good enough for me - I know my mind is made up now.
Thanks for posting.
    • Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
    • So, got some bits..   New oil filter housing gasket (main problem I'm trying to fix -see leak above)  While you're in there's: New belts, pulley and tensioners.  Vanos oil line New oil drain valve New water pump and pulley  New fumoto valve (all my cars have these). Some of this stuff seems ok now that I've pulled it out but I still have no idea how old it all is.  The belts looked fine and then I noticed this. Like somebody has hooked it with a pick.
    • As the title suggests, Looking for some comfortable replacement seats that will suit/fit an R32 GTR. Purely road use.  Happy to travel to the Tweed, Gold Coast and Brisbane area. Possibly Sunshine Coast for the right seats. Show me what you got! Thanks in advance.
    • Customer states,I got an oil leak.  Customer was raht.
    • Hi friends, I recently got myself back into an R32 GTR with factory seats. The seats themselves are in excellent condition but the drivers seat is a bit tight for my back and become uncomfortable after about 20min of driving. The passenger seat is a little better so I'm not sure what is going on there, almost as if the drivers seat is newer and has not been worn in.  Anyway, I'm looking to replace them with something thats going to be comfortable for road use.  I was looking at these replica seats from Crank Motorsport however there has been a number of reviews of the company that aren't great so i'm a little skeptical.  https://www.ebay.com.au/itm/185466689021?_skw=r32+GTR+front+seats&itmmeta=01JKS72VG115M2Y3KBGCBCWYDD&hash=item2b2ead15fd:g:cMAAAOSwhhZlsIpK&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKl6v17FmqPFPHrHp4kFm2I9VMAXrpZg5R8sUXH6QLUAkliQu34NiG%2F84PJ05lKf2iGboUiWpWbvHYPYKsT154rul3I%2FaGRskpG8VfgyrwC9%2BdRj7uoDAPGJH%2FVprfvd6pgAN2XmUz6buE9YHvOPCKhtJfsQXhEzwgmVTcIwEkkV0A1r%2FkyJYMmQK0OKLI%2FrM%2FQLzeAOkN9B6WLAPrNyFlml%2FkG%2BYzkTXGJ8LN%2B0NCSLfczQGSYeJqPfvMFMgDL2gOD%2BPWb3sX1D1A6PxY5jqyMGey7zin4sDqrUrA7CpqLLpA%3D%3D|tkp%3ABFBMmriLp55l I also live In the Northern Rivers and these seats are in Melbourne so I can't even try them out before purchase.  Is there anywhere/anyone around the Gold Coast, Tweed or Brisbane area that would have a decent selection of seats I could test out before purchase. A lot of these places seem to be in Sydney and Brisbane. Maybe there's an individual who has an after market item such as Bride or Recaro I could quickly try? Thanks in advance!
