Have rb26 standard block needs 5 thou over bore no cracks or leaks !!! Make me a offer . Have rb26 crank perfect condition . Have conrods perfect condition . Have standard pistons 3 of them in good condition . Have water pump not sure if N1 or not . Oil pump there not sure if N1 or standard . Have standard 4wd sump for sale . Thermostat housing is there too just inbox me your offers or send us a text 0421854393 !! Located in Rooty hill western Sydney :) cheers fellas
https://www.sau.com.au/forums/topic/403738-rb26-part-out-western-syd/
