hi guys,
when i start my r32gtr - only on start up for about 2 sec i get this high pitch squeal which to me sounds like a fan belt, so i sprayed a bit of silicone spray...its not this.
what could it be?
if my explanation is not clear - i can record a short clip & post it here
https://www.sau.com.au/forums/topic/403766-unusual-squeal-on-engine-start-up/
The drive gear in the starter slips as the engine speed increases beyond cranking speed and it's not uncommon for them to squeal. Especially when they are full of clutch dust. Holding the key in start position for a second longer(ie allowing engine to reach idle before releasing key) should lengthen the noise if it's the cause.
I wouldn't have used Silicone spray, you will never get the sh*t off the pulleys. The only thing worse than that would be Belt grip (makes me shudder just saying the name)
  • Like 1
Just had a similar issue with my 33 GTR, Shouldn't really sound like a belt thou. More like a whine than a squeel. Mine was the starter not dis-engagaing after starting for a second or 2!! Very embarrassing in public places.. All i did was removed starter bolts and pushed starter back enough to get access to the gear and put quite a bit of graphite powder on and behind the gear. After about 5-10 start ups all gone ;-) Dont know what caused it to be honest.
Had previously thought about making a DIY to strip and re-oil but most out there will likely require brushes/bushes etc and didn't want to go too in depth. Removed/repaired an Sau members starter from 33gtr and there was a full handfull of clutch material in the housing and drive gear was bound up. Heaps of contact cleaner got it out. But greasing etc without disassembly would never have fixed the problem.
So that's a negative on four seasons lube. Save it for your next birthday:)
If you use your lube
yeah i did a full strip on it...didnt look to be in too bad condition..there was some clutch dust though...
I used grease but only on the cogs I think (still a mistake i know) I used something else on the shafts, was lithium or PFTE grease from a spray can from memory...
So whats the correct procedure then and i will do it again...
Fill both the bushes with oil then press your finger into them to force it through as they are porous. Grease on reduction gears which won't be where the noise is from.
Drive gear should lock up one way and free the other. Contact cleaner through the gap to get clutch dust out until its smooth. Touch of grease on worm drive under drive gear. Also touch of grease on solenoid pivot points. Noise will almost certainly be from drive gear if it's from the starter. If its still rough after cleaner get another for 30 or so
i still haven't gotten around to inspecting the noise i have BUT i did notice is that the noise is there when the engine is cold...once warm, the noise disappears which leads me to believe it is a noisy fan belt (or my supercharger belt as ARTZ commented above, haha)
Doubt the starter would be temp sensitive. Better check it out before something seizes.
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
