All.
I have a set of 4 Hoosier D.O.T. Approved Drag Radials in 275/40/17. The come fitted to R33 GTR rims.
If you want to take your GTR and run some epic street legal passes, these are the tyres you want. They are soft as butter and you can literally press the tread in with your thumb.
I managed a 1.5X 60fts on an airport surface in my GTR... So there is even better 60ft times if you are racing on a properly prepped drag strip.
Condition:
Drag Radials - done less than 20 passes, outsides of the tyres are still in new condition, not even 1mm missing. They have been correctly stored for the past 7 months since last use. No burnouts were done on them (due to being on R33 GTR with no RWD setup).
Hoosier part number: 46730
R33 GTR wheels - Seen better days, some gutter rash here/there. Overall paint in average condition as they were my circuit rims prior. They do have centre caps.
RRP for the tyres is $374ea - $1500. I got them for $1300
post-709-0-75223600-1343511466_thumb.jpg post-709-0-53872900-1343511488_thumb.jpg
Price: $1550 - includes 4x rims AND the 4x tyres.
Price: $600 for 2x rims AND 2x tyres
Delivery @ buyers expense, i get heavily discounted rates so it's not an expensive endeavour.
  • 3 weeks later...
If you include shipping I'll offer $600.
Not really required right now seeing as I have a 5 cylinder RB26, but hopefully I'll sort that out soon
  • 3 weeks later...
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
