Hey guys, I picked up this pretty lady last night. Its a 1990 GTST 4 door 4wd.
NPG coilovers, extreme 6 puk clutch, r34 neo turbo, 18x8 f and 18x9 r work wheels (any one know the model at all?), f & r strut braces, 3" exhaust, apexi pod, HKS boost gauge, front mount intercooler, m spec factory kit. Also threw in some HID's i had lying around.
Plans are for a new steering wheel as the current one is haggard as fook haha, then upgrade the fuel system (what size injectors is good?). I'm aiming for 200rwkw but time will tell.
This car makes a welcome change from previous cars including an auto charade, and 2 v8 commodores haha
I went for a lovely drive yesterday to see how the car felt on some of my favourite roads, went down the local autopro and picked up a little jack coz i knew the car didn't have one. What i didn't do was check my spare but i knew it was there and honestly how often do you get a flat.
100kms later almost home hear a little bang sorta noise, car starts pulling to the right a tad. I was devastated, started smelling the tyre so i pulled over, got the wheel off, got out the spare. OH FOOOOOK its dead flat. I should've checked it and i felt like a moron. I didn't wanna f**k my good wheel so i bolted up the spare.
Then begun the fun journey of limping the car to the nearest servo barely going fast enough to keep the car from bunnyhopping.
Finally get there and just to add to my luck the servo doesn't have a pump, i managed to burrrow one from a lovely old man which plugged into the cigarette socket. Spare didn't wanna take air. So i start ringing all the people i know to come down and go get my good wheel repaired while i waited with my car. Someone came down i basically threw the wheel through their window and told them to just get it fixed. Turns out the tyre had a gash in it and needed to be replaced, even better no where in my town had that size.
They came back and gave me a lift home, jumped in my other car and went looking for somewhere with the tyre i needed. 2 hours later i was back at the servo putting on the good wheel in the rain generally not having fun.
Touch wood I only get problems like this with this car haha
https://www.sau.com.au/forums/topic/403800-r32-gtst-4-door/
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
