Just remember; anything you put in your washer bottle will end up on your paint.
I don't wash my car with Windex. :no:
Well it contains
* isopropyl alcohol
* propylene glycol
* ammonia
I was looking up what these might do to rubber & paint > went off to sleep lol
Well it contains
* isopropyl alcohol
* propylene glycol
* ammonia
I assume the first two ingredients are bad as they are alcohol based?
Can't be good for windscreen seals either..
I use Windex on a rag to clean off cutting compound as I was recommended isopropyl, but only in small doses ..I wouldn't put it in my washer, not straight anyway maybe watered down a lot...sounds like a waste of money anyway Windex isn't cheap..just get washer mix from SCA or something its like 5$ and lasts ages..I bought a bottle and sharing it between 3 cars has lasted over a year, still have half a bottle left..
Dont do it
It kills your paint, rubber, streaks like hell on glass and paint and makes your wipers dry out and shutter / hop destroying the motor and blades as they move across
The evaperation is too fast at speed and it makes a mess
The only time you need anything beyond water is if it gets below freezing ( which will crack your bottle and lines ) even the stuff posted above stuffs your detailed car up , best left for old crappy cars and mud bog trucks
You can buy paste glasswax and it works to keep bugs off and water stains or rain ex if applied in a few thin layers works but only at speed , its meant for race cars and planes
Just buy decent blades and change them yearly
And just like anything rainex and wax wears off , do it as part of a detail job min to keep acid rain or tap water from etching the glass
Edited by Carbon 34
Nothing beats new blades, So quite, No streaks, No mess. Cheap and under 10 min to install
Though i have been looking for a good Glasswax like rainex ect.
Can anyone comfirm if thats the sam stuff the race cars use when they have stripped all wipers and washer bottles?
I use Rain-X on my windows, and they do a washer additive that I also use. It doesn't leave any visible residue or spotting on my paint.
It seems to stretch out the time between reapplication of Rain-X, especially in the wiper track; which always wears off first.
Definitely agree with new wiper blades; also helps with reducing wiper track scratching, as the blades get older with more rubbish embedded in them.
Edited by Daleo
Yes its the real stuff but built up over lots of thin layers to work, you can buy glasswax from USA its pretty cheap under 20 bucks some megs wax works but beware some waxes stuff the wipers and they shudder bad , those silicone blade suck too unless its a downpour , splatters of water they clean to well and the backstroke is bouncing blades
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
