Just remember; anything you put in your washer bottle will end up on your paint.
I don't wash my car with Windex. :no:
Well it contains
* isopropyl alcohol
* propylene glycol
* ammonia
I was looking up what these might do to rubber & paint > went off to sleep lol
Well it contains
* isopropyl alcohol
* propylene glycol
* ammonia
I assume the first two ingredients are bad as they are alcohol based?
Can't be good for windscreen seals either..
I use Windex on a rag to clean off cutting compound as I was recommended isopropyl, but only in small doses ..I wouldn't put it in my washer, not straight anyway maybe watered down a lot...sounds like a waste of money anyway Windex isn't cheap..just get washer mix from SCA or something its like 5$ and lasts ages..I bought a bottle and sharing it between 3 cars has lasted over a year, still have half a bottle left..
Dont do it
It kills your paint, rubber, streaks like hell on glass and paint and makes your wipers dry out and shutter / hop destroying the motor and blades as they move across
The evaperation is too fast at speed and it makes a mess
The only time you need anything beyond water is if it gets below freezing ( which will crack your bottle and lines ) even the stuff posted above stuffs your detailed car up , best left for old crappy cars and mud bog trucks
You can buy paste glasswax and it works to keep bugs off and water stains or rain ex if applied in a few thin layers works but only at speed , its meant for race cars and planes
Just buy decent blades and change them yearly
And just like anything rainex and wax wears off , do it as part of a detail job min to keep acid rain or tap water from etching the glass
Edited by Carbon 34
Nothing beats new blades, So quite, No streaks, No mess. Cheap and under 10 min to install
Though i have been looking for a good Glasswax like rainex ect.
Can anyone comfirm if thats the sam stuff the race cars use when they have stripped all wipers and washer bottles?
I use Rain-X on my windows, and they do a washer additive that I also use. It doesn't leave any visible residue or spotting on my paint.
It seems to stretch out the time between reapplication of Rain-X, especially in the wiper track; which always wears off first.
Definitely agree with new wiper blades; also helps with reducing wiper track scratching, as the blades get older with more rubbish embedded in them.
Edited by Daleo
Yes its the real stuff but built up over lots of thin layers to work, you can buy glasswax from USA its pretty cheap under 20 bucks some megs wax works but beware some waxes stuff the wipers and they shudder bad , those silicone blade suck too unless its a downpour , splatters of water they clean to well and the backstroke is bouncing blades
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
