Track Day - 29 July 2012 Midvale Speed Dome
It's near that time again...
Track day at the Midvale Speed Dome.
There are up to 20 places available, but I'm ideally looking for 16 -17 drivers.
It will be a full day and will cost $160 including lunch.
It's a short course, so it suits quick accelerating and good handling cars.
It will be an Autokhana/Superkhana style event, which essentially means driving really fast around a series of tight corners and short straights.
It will be a FULL day event, but obviously you can come and go as you please.
You will need your own, or access to the following things;
Licenced & roadworthy car
Helmet
Long sleeve shirt and pants (cotton is best)
Closed in shoes
Your car will be lightly scrutineered before you are allowed to drive it on the track.
Basically, make sure the following things are done;
Battery is secure
Seatbelts lock under tension
Tyres are not completely bald
Loose objects are removed from cabin
Your car is not falling apart
Your car is not leaking vital fluids
Cost is $160 - payable before the day.
Price will include Hot Dogs and drinks for the drivers only.
Spectators are most welcome, but will need to provide their own food and drink.
You will need to bring your own;
Seats/blankets/cushions to sit on during the day.
Sunscreen, just in case
Insect repellent, just in case.
Don't forget your tools, and spares just in case!
There's plenty of room to make a mistake, so rest assured that the worst that will happen is your car might get a little dirty.
It'll be good fun, and it'll be at mostly slower speeds, so drive at the pace that you're most comfortable with. Your times will improve the more you drive.
There's a chance of some professional instruction on the day too.
The money is non-refundable, so if you can't make it, find someone else to take your place.
Make sure your car is reliable, and will last the whole day. The price is the same whether you drive for 1 run or 20.
You may drive someone else's car (with their permission of course!), but that car will need to scrutineered also if it hasn't been already.
Lastly, the track is for everyone who is driving on the day. Each run takes about 1 minute 30 seconds.
Don't dawdle, remember who you're after in the running order, and standstills are for Motorvation.
If you're deemed to be unsafe on the track, you get 1 warning only. After that, no more driving for you.
You will need to let me know via PM or e-mail, if you intend on driving ASAP so that I can advise and pay the venue, and sort out your running order for the day.
Contact me with any questions
Spots are filling up fast!
If you'd like to drive in this event, you'll need to PM me ASAP to let me know!
If you're planning on coming down just to spectate, then just show up on the day... :)
Yeah me and the old boy will cruise over and show some support, wave some flags or something haha
Will be good to see some action even though I can't be apart of it while my car is in the workshop
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
