Has anyone find out who can get our Bose-Clarion PN-2414e unit with this error fixed in Australia or overseas and for how much? Or better yet, has anyone fixed it themselves?
There are a few reasons for this error to appear -
Circuit board problem
Cracked plastic gear
Jammed mechanism
The reasons for my CD ERR FO is the mechanism jamming which occured when I was switching tracks. I took the CD-Changer apart with the help of my father-electrician, but it proved too complex for him to figure out which part is stuck. The mechanism looks intact and not tampered with before - the car had just 40k on clock when bought.
The solutions I am considering -
Buying new unit from the US ($300), but it is missing one of the output at the back - probably for Navigation which I have.
Sending old unit to the US for repair ($150 repaired plus shipping)
Edited by Stayer
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/
You can get them fixed in Aust, but I believe the cost is significant. It would be worthwhile looking at the double DIN facia and an aftermarket head unit.
If you want to keep a factory type unit, you could post it to the US for repair. Or you should be able to pick up a 2nd hand G35 head unit for less than $300. I picked up a bose G35 head unit for US$170. If you decide to go down this route, you have the obvious risk of it not working when it gets here.. If you go new or 2nd hand from USA, make sure you buy like for like (bose with navi with a G35 bose with navi), then it should be a simple swap. And the G35 HUs can play MP3 CDs.
The hard part will be getting your CDs out of the old unit.. I believe it requires major surgery..
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6426268
thanks for that! where did you get it from if you don't mind me asking?
also, isn't the G35 unit you bought comes from Series 2 G35? I believe Series 2 (2005) V35s had MP3 player already.
I would be happy to get Series 2 Head-Unit with MP3 function, however, not sure if it would fit Series 1 as Series 1 has climate controls inside it and Series 2 doesn't.
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6426415
That's a good point, you will need to get a S1 deck if you have a S1 V35. I believe the connectors are different between the S1 and S2. Also, as you know, the face panel is different, and you will probably need this from the G35 too.
The S2 V35 doesn't play MP3s.. it does had a MD player, perhaps that is where the confusion has come from? That is the main reason I got the G35 HU, as I wanted MP3 playback. and it was cheaper than the Double DIN setup or the iPod I/F.
I found mine on the G35driver 'for sale' section. They pop up on there every now and then.
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6426502
I had the same issue when I got my car ages ago. I simply removed the unit and give it a nice kick, then all the CDs came out, but mine had other issues (no sound at all) you might wanna give it a go. Remove the unit and shake it a little bit. or better replace it with a 7" DVD player as I did.
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6437465
  • 3 weeks later...
  • 3 weeks later...
sent 3 of you the link too
to be clear, that's the link to the offer of repair service
however, after I told him that I'm from Australia, he offered me to sent CD-Mechanism for the cost of repair to save me on shipping costs
also, CD ERR F0 may results from different problems (electrical, for example), mine was purely mechanical as CD-Mechanism stuck while I was changing disks on the move
so, talk to the guy about your problem
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6492626
  • 5 months later...
I do like how you said "the car had just 40k on clock when bought." .... I haven't seen a V35 go through the Jp auctions with 40k on it since about 2005, yet you can find them all along Parramatta Road and other similar places with these sort of km on them. Truth be told for under $100 a guy can come out and make your odo say whatever you want. Just sayin'.
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6727225
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
