Has anyone find out who can get our Bose-Clarion PN-2414e unit with this error fixed in Australia or overseas and for how much? Or better yet, has anyone fixed it themselves?
There are a few reasons for this error to appear -
Circuit board problem
Cracked plastic gear
Jammed mechanism
The reasons for my CD ERR FO is the mechanism jamming which occured when I was switching tracks. I took the CD-Changer apart with the help of my father-electrician, but it proved too complex for him to figure out which part is stuck. The mechanism looks intact and not tampered with before - the car had just 40k on clock when bought.
The solutions I am considering -
Buying new unit from the US ($300), but it is missing one of the output at the back - probably for Navigation which I have.
Sending old unit to the US for repair ($150 repaired plus shipping)
Edited by Stayer
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/
You can get them fixed in Aust, but I believe the cost is significant. It would be worthwhile looking at the double DIN facia and an aftermarket head unit.
If you want to keep a factory type unit, you could post it to the US for repair. Or you should be able to pick up a 2nd hand G35 head unit for less than $300. I picked up a bose G35 head unit for US$170. If you decide to go down this route, you have the obvious risk of it not working when it gets here.. If you go new or 2nd hand from USA, make sure you buy like for like (bose with navi with a G35 bose with navi), then it should be a simple swap. And the G35 HUs can play MP3 CDs.
The hard part will be getting your CDs out of the old unit.. I believe it requires major surgery..
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6426268
thanks for that! where did you get it from if you don't mind me asking?
also, isn't the G35 unit you bought comes from Series 2 G35? I believe Series 2 (2005) V35s had MP3 player already.
I would be happy to get Series 2 Head-Unit with MP3 function, however, not sure if it would fit Series 1 as Series 1 has climate controls inside it and Series 2 doesn't.
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6426415
That's a good point, you will need to get a S1 deck if you have a S1 V35. I believe the connectors are different between the S1 and S2. Also, as you know, the face panel is different, and you will probably need this from the G35 too.
The S2 V35 doesn't play MP3s.. it does had a MD player, perhaps that is where the confusion has come from? That is the main reason I got the G35 HU, as I wanted MP3 playback. and it was cheaper than the Double DIN setup or the iPod I/F.
I found mine on the G35driver 'for sale' section. They pop up on there every now and then.
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6426502
I had the same issue when I got my car ages ago. I simply removed the unit and give it a nice kick, then all the CDs came out, but mine had other issues (no sound at all) you might wanna give it a go. Remove the unit and shake it a little bit. or better replace it with a 7" DVD player as I did.
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6437465
  • 3 weeks later...
  • 3 weeks later...
sent 3 of you the link too
to be clear, that's the link to the offer of repair service
however, after I told him that I'm from Australia, he offered me to sent CD-Mechanism for the cost of repair to save me on shipping costs
also, CD ERR F0 may results from different problems (electrical, for example), mine was purely mechanical as CD-Mechanism stuck while I was changing disks on the move
so, talk to the guy about your problem
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6492626
  • 5 months later...
I do like how you said "the car had just 40k on clock when bought." .... I haven't seen a V35 go through the Jp auctions with 40k on it since about 2005, yet you can find them all along Parramatta Road and other similar places with these sort of km on them. Truth be told for under $100 a guy can come out and make your odo say whatever you want. Just sayin'.
https://www.sau.com.au/forums/topic/403882-cd-err-fo-fix/#findComment-6727225
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
