Hey im looking 2 upgrade my exhaust manifold and i came across these on ebay.
Im just wondering if any1 has used these or no if there any good, as they are at a pretty good price nd im very tempted 2 buy 1 as a low mount tho.
https://www.sau.com.au/forums/topic/403890-any1-using-these-manifolds/
The positioning of the wastegate pipe scares me. Also, contact the seller to find out the wall thickness... But in answer to your question, no I haven't used this 'exact' one.. The welds look neat enough though.
EDIT: Just realised you said "as a low mount", in which case... As below.
Edited by Dajae
It's well known that china stainless manifolds crack over time.
What set-up do you have?
Unless over 300rwkw on PULP or 340rwkw on E85... Stock manifold is tried and proven to be perfectly fine - so stick with it.
Well im in the middle of doing up my engine atm and my aim is 4 around 280-300rwks on united 100 octane.
Ive currently got
Hypergear ATR43SS2 with .82 rear
Apexi power fc + adjustable boost controller
Nismo 740cc injectors
Z32 afm
FMIC
3" metal induction pipe
Pod filter in plazmaman cold air box
Blitz BOV
Xforce turbo bak zorst
Walbro fuel pump
Splitfire coil packs
I was told that the stock manifold was only good 4 280rwks max. So was gunna just replace manifold when i get my new turbo put on. But if there good 4 around 300rwks i might just keep it nd see how it goes.
I dont think these a china copies either, Says theres aussie made.
Edited by BLK-51N
You do not need an after market manifold.
The manifold is tried, and proven. Whoever said it was a restriction does not know what they are talking about.
And without even reading the ad, I can tell you it does not state they are locally made.
Why? Because they look like every other China manifold.
im using one but slightly modified. had the external gate pipe re done and boost doesnt spike and has f-all bleed off.. Not a bad piece of equipment after modifying. hasnt cracked or warped yet
also what ash said.. you can make pretty good power using a standard manifold.
Edited by LTHLRB
You can run an 50mm external gate from the factory exhaust manifold, which results the most significant gain without having to go through the hassle of changing the whole exhaust setup.
The only problem doing it off the manifold, though, is that they are split pulse from factory so if you gate off the manifold you only get 3 runners bleeding off
You can dill at where the two main collectors meets then mill the divider 20mms in and weld a screamer from there. I saw couple done and worked that way and getting better result then externally gating from the turbine housing.
