hey guys,
Was looking under my hood today (STOCK r34 gtt) and i was just wondering where the location of the turbo is found?
Does the stock turbo look like any other snail shaped turbo? I can't seem to locate it lol. I know it's probably a really stupid question, but i must know!
https://www.sau.com.au/forums/topic/403994-where-is-the-turbo-located/
  • Replies 49
Next to the passenger side strut tower.
it will be heavily concealed by pipes and heat shields.
its not that silly a question, when i was a teenager and only first getting my hands dirty it was like an epiphany moment when i found the turbo on a friends car. admittedly they thought that was really lame but i was still in awe of my own achievement :P
FI section delivers.
This. To the humerus thread directory please.
But yes, it's below heat shields and piping, you won't see it if you don't know what you're looking at. better chance of seeing it in it's "snail" entirety from underneath the vehicle.
If you look down beside your passengers shock tower, you should see this:
Its under that. Grab a torch and shine it around and follow the intercooler pipes. You'l see the NISSAN stamp on the compressor cover. Unless, its lol, and NA
its not that nice to look at anyway... :unsure: lol its a small crappy thing, best not seeing it .. keep it covered and send it to hypergear , when it comes back you can drool over it.. :yes: then you will be happy to have it naked for all to see lol :mage:
Edited by SliverS2
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 馃槄
