Hey Guys, this is my first thread on here, hopefully some of you find it useful.
I have been searching and trying to work out what each car will come with in the auctions is a headache. Asking an importer to look at 4 cars a day to find out they arent a premium isnt fair, so i decided to work it out for myself.
What you need to do is find the car up for auction on this site: http://jpcenter.ru/
Once you found the car, click on the "MONTH OF PRODUCTION" button
Type the cars Japanese VIN in there, for a v35 Coupe it will be CPV35-XXXXXX where the X's will be a number on your auction sheet.
From there you need the "code of a model"
The one im doing for this test looks like this - GLJARVNV35EDAA-C--
The first lot of numbers in the code are unimportant, you know what they represent by looking at the car
The important numbers/letters start from the number 7.
7 = Your transmission type, where N is 5 speed auto, i think manual will probably be M
After that nothings important until 14, where 14,15,16,17,18 represent what factory option packs you have :)
Please note i only had access to the sedan one and i dont speak japanese well so there could very well be mistakes or options missing
14 is concerned with what external options you have
The possible options are
GLSSW = Privacy Glass
COAT2 = "Bok Doko - eight off seven in a superuser" (WTF does this mean?)
DWHLV = 17 215/55 wheels/tyres
ROOF3 = Garasusanru electric step (sunroof?)
Option 15 is to do with navigation
- = Regular
(A) TELv2 - Tv Navigation DVD (shiki?)
(B) ETCS2 - ETC + TV Navigation Formula DVD
©TELV4 - Navigation with CD
Option 16 is to do with the CD player
CLAS2 = BOSE plus dual zone climate control (Premium pack?)
CLAS3 = ??? with BOSE
CLAS4 = ??? with BOSE
CLAS5 = ??? without BOSE
CLAS6 = ??? without BOSE
STDv4 = Leather Fronts
BLTT5 = 3 point type seatbelt, Power drivers seat?
SPI3 = one rear wiper frame a rear spoiler and opening
SPI2 = Rear spoiler and a link frame □ Assignable
Option 17 is to do with performance options
ACCS3 = Adaptive Cruise Control system
VDCs2 = VDC
DIFF6 = LSD
I will post up an image soon so you can reference what yours will have :) Happy shopping!
https://www.sau.com.au/forums/topic/404005-option-codes/
Some further translations:
Clas3 - P collection with BOSE
Clas4 - S collection with BOSE
Clas5 - P collection without BOSE
Clas6 - S collection without BOSE
STDV4 - Leather Seat with Heating Front Only
BLTT5 - 3 seatbelt rear with curtain airbag and active head restraint
SPOI3 - Rear spoiler with side skirts and rear wiper
SPOI2 0 Rear spoiler with side skirts
I have no idea what the difference is between a P collection and a S collection. Presumably P means Premium and S means Sports. Looks like Nissan had the "S" and "P" designations for the V35 as well (as is the case with the V36).
https://www.sau.com.au/forums/topic/404005-option-codes/#findComment-6430221
  • 8 months later...
Sorry to trawl this thread up from the past, I have been using your codes to browse and I can say they aren't accurate for sedans past 03 (believe me I just bought an '03 with a D code Option 16 and it doesn't have side airbags, it has the heated seats with full leather option, but i already knew that before buying it). I did however find a better way by accident today, it is quicker and it doesn't require translation:
go here
http://nissan.epc-data.com/
type in the japanese VIN in the section that says: "Please enter full frame number:"
you will then get to a page like this: (here is one i prepared earlier with alot of options)
http://nissan.epc-data.com/skyline/hv35/6820-vq30dd/?frame_no=hv35-204441
if you look at the "Spec code" section it will give you the option code (similar to those in the original post) if you hover over it, it will give you a tooltip with an explanation of which code is which IN ENGLISH.
Enjoy! and I assume this does more than just V35s!
https://www.sau.com.au/forums/topic/404005-option-codes/#findComment-6787411
This webpage - http://nissan.epc-data.com/skyline/v35/6815-vq25dd/body/680/68520/ suggests that it is either 250GTM Navi Edition or 350GT Premium Leather Package (as opposed to CLAS8 which is Premium Spec).
I found another page that says it's navi edition for a Stagea NM35, so that ties in with the above. Do you have factory nav?
https://www.sau.com.au/forums/topic/404005-option-codes/#findComment-6788512
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe will give me my power goals and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
