Just thought id share some recent experiences with everyone.
Just bought a Greddy Oil Catch Tank, the new 1L one. Now before buying i was assured it was actually an oil/air separator.
Now it arrived today, only for me to unwrap and realise that i just paid good money for a hollow bit of aluminium. :D There is no baffles etc inside so how is thing supposed to scrub oil from the crank case gases etc etc before being re-circulated back ino my inlet?
I could have just made my own you beaut, home grown, oz designed orchy bottle / bong catch can for $5.
So be wary the next time someone tells you that the Japanese call their oil/air separators oil catch tanks (ala surge tanks are actually inlet manifolds)
Oh well at least its shiny and is better then nothing at all :)
https://www.sau.com.au/forums/topic/40402-greddy-oil-catch-can/
  • Replies 103
I think yer supposed to add yer own baffling, ala SK style - some steel wool inside a stocking. Lets air through but catches vapourized oil, while stopping wool from going back into engine.
Id prefer this "replaceable filter" than cleaning a 500ml bottle full of oil out.
Who makes a "good" one?
LW.
well anyone that has what a proper Air/Oil spearator catch-can needs
Same as what Roy said he wanted (should have got)
OH... i c!
I dunno... lots of the ones i've seen come out of Jap, are just what Roy got.
Tins cans that are nice and shint and do little else.
Probably getting one custom made here in Aust by a performance place would be best bets.
damn i was gonna get one from gcg but thought it wouldnt be up to scratch to the greddy one :P
just called the official trust/greddy distributors and asked if the 500ml one has baffles or if its just a hollow can.
i quote
"wouldnt know mate, never pulled one apart"
me "so i cant get an answer on that?"
"nah wouldnt know mate"
Any metal fabrication place will make any design you take to them (as long as its possible) You can even specify material selection and baffle design (if you want to).
My catch can has no internal baffles from the metal fab place, had two weld bungs welded on, and a fitting for a small filter to attach to, and a bracket to attach it. All up it cost $120. And the best thing is its custom and only one like it.
The prob with the GCG type and the one Benno describes is that gasses are filtered tehn released into the atmosphere. So after a period of time you get an oilf film over most parts in your engien bay (Well at least i did)... and aint exactly legal.
With a proper oil air separator the air is scrubbed of oil then the filtered air (not 100%...but good enough) can be returned to the inlet tract with negligible impact.
I was going to go custom as per my want, but i wanted aluminium which meant i cant weld it, and even to buy and cut up myself, then to have a bloke weld it for $50, well for $155 i was willing to pay the extra for convenience...looks liek ill just make my own out of stainless (heavy but will at least work how i wasn it to)
Anyway, ill give this thing a go and see if it works ok, i may just put a bit of gauze in the return pipe liek the std setup has for the pipe that goes upstream of the turbo.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
