ok i have done the test with the greddy cans....i have a 1L Genuine greddy catch can in my r32. Its only hooked up to the exhaust rocker cover and the inlet is still connected into the plenum...My catch can is hooked up so it goes back into the inlet......Anyways after the last track day i did..(a fair bit off trashing involved) when i got home i noticed the catch can was around 1/5 full...the pipe that came from the motor to the catch can was just that golden brown oilly colour...but then the hose that went from the can back to the inlet was absolutly spotless....this just tells me a hollow can does its job perfect..you dont need baffles and steel wool! i think from the turbulence of the blow by gas going around inside the can the oil particles will stick together to form bigger particles then fall to the bottom off the can....thus how these cans work...
regards luke
  • Replies 103
Just thought id share some recent experiences with everyone.
Just bought a Greddy Oil Catch Tank, the new 1L one.  Now before buying i was assured it was actually an oil/air separator.
Now it arrived today, only for me to unwrap and realise that i just paid good money for a hollow bit of aluminium. :)  There is no baffles etc  inside so how is thing supposed to scrub oil from the crank case gases etc etc before being re-circulated back ino my inlet?
I could have just made my own you beaut, home grown, oz designed orchy bottle / bong catch can for $5.
So be wary the next time someone tells you that the Japanese call their oil/air separators oil catch tanks (ala surge tanks are actually inlet manifolds)
Oh well at least its shiny and is better then nothing at all :)
yeo know where your coming form, bought an oil catch tank and it has rust on the piping inlets and the welds hadn't been finished. Ended up making my own which is what i should of done in the first place :uh-huh:
  • 7 months later...
Hey SK.  I've done my own diagrams from my own understanding, if you'd like to tell me what’s right & wrong 'advantages - disadvantages' about each diagram that would be great.
Owww & please automatically assume that the PCV & so forth are blocked like in your first Zero% plumb back diagram.
From my can design i would think i could only use the B. or C. setup.  Personally I think i'd like the A. setup but would need a can with valve at top & bottom?
If anyone wishes to do diagrams too here is a pic they can use. :D
So do i run both lines from both cam covers to the catch can? as my can has a breather on the top
SK, My can doesn’t have a breather on top, just two nozzles, can i run both cam cover lines to the can or must i have a breather to release pressure? If so I spose I could run one line to the can & put a filter on the end of the other nozzle, but i dont really want to have an atmos setup & i also dont want oil going into my plenum & so forth, thats why i thought I could run 1 line in & the other line to the sump?
BUMP on this questions.
believe it or not I still haven't installed it yet, but I'm getting my 100K service next week hopefully, so going to get it done then.
Does any one run the 'out pipe to sump' set up? Sounds most attractive to me if do-able enough.
  • 8 months later...
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
