I've decided to go bigger again and move onto the 7th turbo on my car!
Complete bolt in setup for S13/S14/S15
Whole setup has less than 1000 km’s on it and half of that was used to bed the engine in.
Precision 935hp 6766SP BB .84 divided housing as new, V-band rear + oil drain flange
6Boost Twin scroll divided manifold with EGT bungs (EGT kit not included)
2 x Tial MVS 38mm wastegates
2 x Screamer pipes
Big black lightweight braided Earls oil return line with fire sleeve (this cost nearly $300 to make alone)
Produced 574kW (758hp) at the wheels on a conservative street tune & 36psi and ran [email protected] on E85
Starts pulling from 3000rpm, hell breaks loose at 5000rpm.
Made 636kW at the wheels on 42psi on a race tune on E99. Will get into mid 8’s.
If you wanted this for a DET, 6Boost are able to cut the VET flange off and weld on a DET flange to suit.
Must go bigger to support my addiction. $3900 firm, will post at buyers expense
PJ 0438 160081
Edited by PJ.
That was the old engine/turbo combo, this one had almost 100kW more atw last drag battle :)
Will separate if need be...
Edited by PJ.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
