I've decided to go bigger again and move onto the 7th turbo on my car!
Complete bolt in setup for S13/S14/S15
Whole setup has less than 1000 km’s on it and half of that was used to bed the engine in.
Precision 935hp 6766SP BB .84 divided housing as new, V-band rear + oil drain flange
6Boost Twin scroll divided manifold with EGT bungs (EGT kit not included)
2 x Tial MVS 38mm wastegates
2 x Screamer pipes
Big black lightweight braided Earls oil return line with fire sleeve (this cost nearly $300 to make alone)
Produced 574kW (758hp) at the wheels on a conservative street tune & 36psi and ran [email protected] on E85
Starts pulling from 3000rpm, hell breaks loose at 5000rpm.
Made 636kW at the wheels on 42psi on a race tune on E99. Will get into mid 8’s.
If you wanted this for a DET, 6Boost are able to cut the VET flange off and weld on a DET flange to suit.
Must go bigger to support my addiction. $3900 firm, will post at buyers expense
PJ 0438 160081
Edited by PJ.
That was the old engine/turbo combo, this one had almost 100kW more atw last drag battle :)
Will separate if need be...
Edited by PJ.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
