Early 1999 R34 --> Sharp
Later 1999 onwards R34 --> Toshiba
Don't pay extra. If your R34 LCD has developed a fault replace it. Or get one of these for the day it will, because who knows whether they will be easy to get in future.
I've got 5 available
$175 shipped, per, Australia wide.
International ok, just ask for shipping cost first.
Edited by moneypit
More info:
Prior to Sep 1999 BNR34 - Sharp
After Jan 2000 BNR34 - Toshiba (till April 2003)
In between these dates - boost may show kg/cm2 for Sharp, kPa for Toshiba
(this reveal is not for Nismo updates though, during the change-over it may be either one).
Youtube video sequence on replacement diy:
Http://Www.Youtube.Com/watch?V=JxkvHyZ0t1o
Http://Www.Youtube.Com/watch?V=ZPFmazkCTRg
Http://Www.Youtube.Com/watch?V = PAqaPcROq6g
Http://Www.Youtube.Com/watch?V=yJUG_Tn8RR4
Http://Www.Youtube.Com/watch?V=z3XrhmmjBpA
You can find these screens on Yahoo Auctions, however they are priced at over 15,000 yen to 20,000 yen ($185 +).
If you need the Sharp panels, please look to auctions.yahoo.co.jp via a buying service. See
http://page4.auctions.yahoo.co.jp/jp/auction/d132764089
unfortunately no, but there is more than one yahoo action buying service you can use.
http://www.mailorder...japan/index.php
http://yahoojapanauctions.com/
and many more
since it is such a small item you need not use a car parts yahoo auctions proxy, any of them would do
You could also try this
http://www.fasttobuy...reen_p7698.html
they actually list a price and a minimum quantity of 1 but I'd try to get a conversation going with a human before paying for anything. And this ebay seller
http://www.ebay.com/itm/LTM084P363-LTM08C351-LTM08C351S-NLL75-8651-11A-Toshiba-8-4-LCD-Panel-/251106559080#ht_1924wt_922
claim to have access to the same part number so you could contact them via ebay.
Edited by rtune
  • 1 month later...
  • 5 months later...
  • 2 years later...
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
