Where I live bnr32 parts are not too easy to come by. My brake booster recently broke and I need a replacement. Does anyone know if a z32 brake booster is an equivalent replacement to the bnr32 brake booster?
Reason why I think the problem is the brake booster . The pedal feel is hard, also I have to press the pedal to the floor with all my might just to get it to slow down. There are no signs of leaking from the master cylinder but I do hear my right brake caliper making lots of noise when I press the brake pedal. I have stock r32 gtr brakes. Anyone know what could possibly be wrong?
Thanks in advance
Edited by 1000AWHP
"I do hear my right brake caliper making lots of noise when I press the brake pedal"
Take the wheel off and check there first.
Give it a a good visual of the caliper, pads and dust/stone gaurd.
Brake Pads ????
I think if it was the booster your brake pedal would go to the floor without much pressure applied.
That's wrong. No booster = hard pedal.
Definitely check the actual caliper function first. But if you need a new booster, you can get your existing one rebuilt at one of the major brake repair shops (I don't mean Midas, etc. I mean places like Adelaide Brake Service, or their equivalent closest to you).
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
