  • Replies 280
Posted Images
I got my entry in. I haven't been to PI before, I paid the full $210 but is it worth doing the Driver Training instead or will I be allowed to get someone experienced to sit next to me and show me around in my first session and then do the rest of the day solo?
I'm in too :)
Gunna be a big contingency of WTA cars there. Big Red, Chasers Evo and maybe more.
Also MSCA have a day on sunday I might have a crack at as well.
Sandeep prob not a bad idea to do driver training. I think you can go on your own later in the day.
I want to do a Sandown first so it's closer to Melb in case I break it... cbf towing it myself until I have my own trailer
same boat
but if i do decide to do Driver training, wont push car much (if at all)
In as well. Busting my PI cherry! Pretty excited!
Whats the status of your thing Snowy? What are the boys up to?
Fixing/upgrading the gearbox. E85 has taken the car past the stock internals limits.
You can see the clutches were giving up even at 3/4 throttle - until it finally broke something at the end there.
I emailed Dirk from WRX club and he recommended I do 1 or 2 sessions with the DT group with an instructor (Richo or Martin?) and then can do the rest of the day solo since DT sessions aren't timed.
Sweet im in. Coming down from Brisbane to have a bash around in my car for the first time in a few months now. Cant wait.
Will be a good cance to see how the hankook RS3's go as well.
Hope the weather holds up!!
This will be my first track day, but I would also like to have a timed lap.
Does that mean that I have to pay two fees?
Driver Training $190
Standard Entry Fee $210.
Total: $400?
Can you do both or just one?
I'm happy to just do the driver training, but I would like to also get a timed lap - so what should I do?
Guest
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
