Sau Vic 2012 Motorsport Championship Round 4 - Pi 21St July
emts
 Share
  • Replies 280
Posted Images
Traction do the AD08's in 255/40 R17 for $380ea. The RS3's are cheaper from RTR, but not by a whole lot, not sure they will last as long as the AD08's is the main thing. If they are 1-2 seconds quicker and last less, it maybe worth it. Maybe.
12-13 Track days and counting now on the AD08's, times are still coming down as the power and aero goes on.
Just for comparison, 1.50.x was my time at PI 3-4 events in a row with AD08's.
Drop a wing on the back, came down to a single 49 that next event.
Drop 40kw into the car, came down to consistent 49's lap after lap each session (then rain).
Drop an extra 30kw into the car, have to see on the 21st.
Where did 70kw come from....850cc, E85, Z32.
ARTZ the helmet needs the Aus Standards sticker, doesn't matter what type. It's in the sup regs on the rex entry page.
Thats good. The Advan stuff seems to be sooo pricey though. Would also be keen to see how the Dunlops Snowy just suggested go; considering their victory in SL clubsprint class. They must be decent!
Whats a set of ADs worth? GTR specs
Hankooks - not Dunlops. And they MUST be fast because they have little flames in the tread. :)
I want to buy locally, but not when I can import and even with shipping charges I can still get a free tyre. ie only pay 75% the local cost. I don't understand why their pricing structure is so much higher then OS agents :(
Looks to be shaping up for a big one - was hoping to be ready for this but no such luck.
Those R-S3's are looking good have added to the shortlist for the evo next. PS3's with their rolly polly sidewalls are no fun on the track.
Are WRX people usually this slow?
oops apologies in order...I was looking in the wrong email folder..they had replied to me already..dont I feel silly. :blush:
On a brighter note I'm in,
aIso picked up some S/h semis cause I really wasnt keen on the idea of nankangs in the wet...I've tried it and I cant get it over 4000rpm in any gear at any speed
repco have fire extinguishers on special for 19$ ...
all I need now is a helmet which I will get next week and i think thats about it yeah...
Might throw my hicas lock bar in if I get a chance too, still wobbly wheeling :D
can anyone learn me on helmets, went to the moto shop and they have cheapie open face jobs for 69$..is it worth spending any more on a brand name or something..I tried a few and they are definately a little more comfortable...is there a better place to shop?
Anyone ever use those old school harley helmets that sit above your ears? kinda like how a bowl would look if you put it on your head lol hearing all the noise from your car without it muffled would be the best and there adr approved
rjays open face was 140$ dropped from about 200$..had a cool skull on it too .
I just dont know if certain brands are any better than others..I know shoeis are tops but at 600$ i dont think so...
most of the cheap stuff was msc or rjays...
I know 2 people that busted there heads up in bike accidents wearing cheapo helmets...both got well over 1/4 million$$ payouts...they were lucky
so, whos running a screamer :whistling:
I have both open and a 200+ close face and the cheap $60 open face is more comfortable and if your with an instructor is easier to hear each other. This isn't targa tassy its PI man up ffs!! Haha
I run a motobike open face, but it is a shoei so decent quality, has great cut outs for glasses built in it.
And was the most comfortable I tried on which to me was the most important.
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
