Need some advice on this. Have read a few different threads.
Details:
Car runs stock bov. 10psi boost stock airbox and turbo. R33 gtst. 3" exhaust turbo back with unknown brand of cat and stock ecu
Problem:
Car runs ok using 10psi. However if you do more than about 4 or 5 bursts of full throttle there is some big bangs from exhaust on decel and you can even hear small bangs when back at idle.
Tps signal seems ok. Checked that on the PFC. Will switch to PFC once I get the Wideband in but would like to sort this first
Exhaust doesn't appear to have a leak. Not sure how old cat is.
When I changed the exhaust the mechanic thought there may be hairline crack in exhaust manifold but there us no soot or any signs of leak from it.
Problem may be slightly worse after fill up.
It still has a charcoal canister connected but one of the pipes on top of engine is blocked off. I.e only one line going to canister so assume no feed back into engine?
What I though it could be:
1. Leaky injector. But wouldn't it not just be after a number of runs.
2. Exhaust leak. Can't see soot anywhere or hear any leaks
3. Overfuel of stock ecu. I had a previous r33 that got down to about 9:1 and still didn't bang so don't think it's that. Running lower boost doesn't seem to change that much
It's just strange that it's only after car is really warm etc that it does it.
The exhaust installer did say the manifold looked as if it had been quite warm at some stage. Metal is very grey from heat. But I think most manis look like that after a few years..
One strange thing that after a fuel fill up I can sometimes hear a vibration noise that cones and goes from near the filler cap.
I opened the cap and the noise stopped and sounded like a pressure release. So might need to check that out. But if there is no return in the charcoal canister and the fuel injectors are shut on decel this shouldn't really be causing the issue
Sorry about the essay.. Got a few things to check I guess. Anyone had this or got ideas?
Cheers
Yeah after a few runs it will be running rich to protect the motor and thats when it seems to bang.
I can do a brap here in there then on decel it will pop and play up.
Shouldnt be to worried.
Maybe chuck the FC in and get it tuned for the boost its running?
Can somebody tell me where the charcoal canister lines run?
Near the crossover pipe there are 2 small tubes.
The top one runs to the charcoal canister (looks like after market as mounted lower than the stock one)
The bottom tube has been blocked off.
Is the bottom one the feed back into engine?
There seems to be some pressure build up in the fuel tank. You can hear some noise around the cap when fuel tank is close to full and when you undo the cap there appears to be quite a release and noise goes away .
I wonder if this has anything to do with the backfire I.e an incorrect functioning fuel tank vent
Thanks. Yes - that sounds pretty important!! Is this the one? Looks like the hose is crushed and quite old..
Anyway - the setup doesn't appear stock. Will need to look at it. It's a huge canister mounted low. See some photos.
Hopefully fixing this may alleviate the issue.
Thanks mate that would be great. If you take a photo near your canister also that would be good.
Looks like someone has fitted a bigger charcoal canister at some point and botched the standard setup! Might try and get a stock canister and plumb things up as per stock
Hmm. Think it's been like that for a while re. wetness around pipe.
Might have to check the PCV and around turbo.
Engine doesn't blow any smoke and doesn't use any oil so dont think blowby could be THAT bad??
There isn't any leaks around the rocker covers which is where you would expect it if it way that bad??
thanks
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
