Need some advice on this. Have read a few different threads.
Details:
Car runs stock bov. 10psi boost stock airbox and turbo. R33 gtst. 3" exhaust turbo back with unknown brand of cat and stock ecu
Problem:
Car runs ok using 10psi. However if you do more than about 4 or 5 bursts of full throttle there is some big bangs from exhaust on decel and you can even hear small bangs when back at idle.
Tps signal seems ok. Checked that on the PFC. Will switch to PFC once I get the Wideband in but would like to sort this first
Exhaust doesn't appear to have a leak. Not sure how old cat is.
When I changed the exhaust the mechanic thought there may be hairline crack in exhaust manifold but there us no soot or any signs of leak from it.
Problem may be slightly worse after fill up.
It still has a charcoal canister connected but one of the pipes on top of engine is blocked off. I.e only one line going to canister so assume no feed back into engine?
What I though it could be:
1. Leaky injector. But wouldn't it not just be after a number of runs.
2. Exhaust leak. Can't see soot anywhere or hear any leaks
3. Overfuel of stock ecu. I had a previous r33 that got down to about 9:1 and still didn't bang so don't think it's that. Running lower boost doesn't seem to change that much
It's just strange that it's only after car is really warm etc that it does it.
The exhaust installer did say the manifold looked as if it had been quite warm at some stage. Metal is very grey from heat. But I think most manis look like that after a few years..
One strange thing that after a fuel fill up I can sometimes hear a vibration noise that cones and goes from near the filler cap.
I opened the cap and the noise stopped and sounded like a pressure release. So might need to check that out. But if there is no return in the charcoal canister and the fuel injectors are shut on decel this shouldn't really be causing the issue
Sorry about the essay.. Got a few things to check I guess. Anyone had this or got ideas?
Cheers
Yeah after a few runs it will be running rich to protect the motor and thats when it seems to bang.
I can do a brap here in there then on decel it will pop and play up.
Shouldnt be to worried.
Maybe chuck the FC in and get it tuned for the boost its running?
Can somebody tell me where the charcoal canister lines run?
Near the crossover pipe there are 2 small tubes.
The top one runs to the charcoal canister (looks like after market as mounted lower than the stock one)
The bottom tube has been blocked off.
Is the bottom one the feed back into engine?
There seems to be some pressure build up in the fuel tank. You can hear some noise around the cap when fuel tank is close to full and when you undo the cap there appears to be quite a release and noise goes away .
I wonder if this has anything to do with the backfire I.e an incorrect functioning fuel tank vent
Thanks. Yes - that sounds pretty important!! Is this the one? Looks like the hose is crushed and quite old..
Anyway - the setup doesn't appear stock. Will need to look at it. It's a huge canister mounted low. See some photos.
Hopefully fixing this may alleviate the issue.
Thanks mate that would be great. If you take a photo near your canister also that would be good.
Looks like someone has fitted a bigger charcoal canister at some point and botched the standard setup! Might try and get a stock canister and plumb things up as per stock
Hmm. Think it's been like that for a while re. wetness around pipe.
Might have to check the PCV and around turbo.
Engine doesn't blow any smoke and doesn't use any oil so dont think blowby could be THAT bad??
There isn't any leaks around the rocker covers which is where you would expect it if it way that bad??
thanks
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
