Hi fellow stagea enthusiasts and owners,
Seem to have encountered a few minor problems the other week, Long story short it was raining extremely hard when I was coming upto a set of traffic lights. Friend of mine was in the car with me and he screamed all of a sudden for me to watch the curb which I was a safe distance away from, Locked the steering wheel to the right hand side after being shocked and completely surprised and understeered up a curb. As a result of clipping the curb and the car going slightly up it I have annoyingly twisted my left radius rod bush and moved my engine crossmember to the right. By about half a centimetre to a centimetre and bent bolts in the process which hold it I'am led to believe according to a friend of mine and his fellow co workers at his tyre fitting/suspension shop. Need some straight answers because I need to fix these issues before my car is sold as a buyer is 100% interested on purchasing it and I have had to put off the sale unfortunately for a bit.
Questions which I have to ask are will I be able to replace my front radius rod bushes with these aftermarket units in the link without having to go aftermarket all the way around the OEM Nissan bushes I got quoted from Nissan would cost me around $90ea thought I may be able to save a bit of money and time whilst making some improvement by going aftermarket before it's sold. http://justjap.com/s...&cat=398&page=1
Second question is what process is involved in rectifying the issue with my crossmember and moving it back to the left where it should be sitting. Got a quote for $800 off a friend but I thought it was a bit steep and cannot justify spending 800 before the car is sold. Have worked in crash repairs for most of my past career but was a car painter so I don't have much experience in the panel beating section but I know for a fact the job is alot smaller then they claim.
Best regards and looking forwards to your responses Chris.
Edited by hks33
When I fitted adjustable castor arms I sold my stock ones for $30 the pair so you may be able to pick some up cheap. Skyline ones will do too. The bushes you have linked to will do the job - if your castor is the same L and R then you can install the bushes so as to provide maximum castor (it won't be that much) or for similar money you could get fully adjustable castor arms. I'm in NZ so can't help you with the chassis straightening!
From what I'm lead to believe I need the GT-R style ones (4wd) only...
Skyline ones will not work from my understanding. What do you mean in relation to my castor from the left and right being the same shouldn't it be the same all ready?
Yes GTR Skyline - here's some:
http://www.trademe.co.nz/motors/car-parts-accessories/nissan/suspension/auction-490757269.htm
Yes castor L and R should be the same but may not be as a result of hitting kerb and might still be out after chassis straightening in which case you can use the adjustables to correct.
If it is the same L and R then the above arms would be your best bet (simple to fit no press needed).
Do the ones which I added a link to in this thread have to be pressed in?
Yes or you can use a vise but if you don't have access to a press then you have to cut/burn the old ones out. If you are not going to keep the car 2nd hand stockers make the most sense.
With limited Stagea parts for sale currently on the forums I would have thought it would be hard for me to find 1 of radius rod bushes though..
Not second hand bushes second hand rods (Stagea or GTR). If you buy the TradeMe ones linked above it should only cost you about $AU 60 or 70 with postage.
No I understand your problem but it is easier to just replace the whole rod with another than to remove and replace the bush. You could buy the ones from TradeMe, or post up a wanted ad in the Stagea and the general "parts wanted" section of this site or phone around the wreckers
Are these adjustable rods with the bushes pressed in? I'm assuming there's no variant between both manual and automatic.
Could you please PM me a price pretty interested if it's moderately priced.
As for your crossmember issue i may be able to shead some light on that. A long time ago i hit a gutter in much the same fashion (although in a crappy VS ute) and the damage to the crossmember was substantial.
First thing to do is check all the welds on the crossmember. If any are even cracked it must be replaced. Ditto if theres any bent areas.
Secondly check it for square. It will need to be measured to make sure its not warped or twisted in any direction. If it is, it must be replaced.
Finally, the whole car must be put on a rack and checked that the chassis is still straight. Its easier than u think to tweak the rails. Uve mentioned the bolts being bent so theres a good chance its tweaked. Although being in smash repair im sure u would have done most of these checks.
As for the $800 that sounds cheap to me. Personally I'd want to make sure everything is done properly with no corners cut. Otherwise the car will never drive right no matter how much u wheel align it. When my old ute was checked the crossmember was bent, twisted and cracked! It also had damaged the radius rod bush, which later turned out to be a bent rod. As well as a split lower control arm bush. So make sure everything is examined very very carefully.
Edited by Raysboostin
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
