Hi All,
Applying for an exemption in QLD to drive a 4 door R32 GTS-T as it falls below the 125kw/tonne ruling.
The exemption states i must supply a
- "Copy of a document published by the vehicle's manufacturer showing the vehicle's kerb weight and maximum engine power. For example, an owner's manual, a letter on the manufacturer's letterheard, or information from the manfucaturer's website.
- a specification information test report, issued by any automotive service provider that has the appropriate equipment, if a document published by the vehicle's manufacturer is not available.
I know that the car weighs 1290kg and has 158kw from factory (122kw/tonne) but i cannot for the life of me find anything on the nissan website or any sort of specification sheet to this fact.
if anyone has a brochure or some sort of sheet to the above requirements i would be forever in debt!
I'm not sure what the limitations on the supporting documents are and don't want to send it off and get it back 2 weeks later to have it fail.
Owner manual with kerb weight + max engine power would suffice.
Thanks
Edited by astorey
Page 23 from the workshop manual has the various engine outputs, 215Ps is 158kw.
The kerb weight will be difficult as these cars had options, HICAS, sunroof to name a few.
I've seen wildy different weights quoted from Wikipedia etc.
Might be easiest to put it on the scales and tender the weighbridge docket.
  • 7 months later...
Hi I was just wondering how you went with your exemption and what paperwork you ended up using?
I'm looking to apply for one for the same model myself so trying to find out what's best to use as even RedBook doesn't have the full specifications.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
