Time has come to strip this, swallow my pride and move on. I dont get no time to use it and can do with the extra money atm. prices are pretty soild.
Wheels:
Weds shocki 18x11 -10 & 18x9.5 +8 (i think no stickers but i measured it) one of the front rims has a slight buckle on the inside. $2200 with fresh rubber federels up front 225/35 and rotalas 235 on rear and for an extra $180 i can get buckle fixed.
Work rezors pair only 18x11 -13 $1500 with fresh rubber
Work (dont know name) pair only $1500 with fresh rubber
Fabouls expand pair only 18x11-13 $1500 with fresh rubber
Suspension & steering:
Driftworks cs2 coilovers 6kg rear 9kg front $1000
Driftworks new offset caster rods $200
Driftworks caster rods $150
Driftworks traction rods$100
Driftworks camber$100
Driftworks toe $100
Driftworks Front LCA $300
Driftworks Rear LCA $300
Tien tie rods and ends pair $200
Caster rod support bracket $100
Rear s15 subframe with alloy offset bushes ans welded supports and powdercoated black $250
Front cross member r32 gts powdercoated black $150
S14 steering rack with new boots $100
Drivetrain:
Rb25 gearbox with Par 1-3 stright cut gears, currently it just got rebuilt with new syncros and forks but it popsout of 2nd now and then, so its going back for warranty but when i get it back is $4000
Exedy twin plate only done a couple of drift days $1000
Tailshaft to suit rb25 box and r200 diff in 180sx $400
Freshly built gtr diff with extra nismo plates and bigger oil case, pair of fresh driveshafts with nissan genuine boots, pair of brand new hubs $1700
Engine:
New NUR RB26 only done 1200ks before i pulled it down and built it. so new block, head, crank etc
Nitto JE forged Pistons
Nitto I beams
Nitto oil pump
Nitto drag series headgasket
Acl race bearings
arp main studs and headstuds
supertech stage 3 valve springs
kelford 272 cams
os giken cam gears
extra oil drain back of head
rear wheel drive sump with tomei baffel kit
ross tuff bond harmonic balancer
all mechine work done by duncan foster and built by mark at mrc dyno
motor just got run in, 392rwkw on 25psi on a 3076
for more info on motor ring me.
chasing $15k
Motor auxelires:
Polished rb26 intake plenum with itbs $600
Accu sump setup with cover made by hypertune and lines $800
Oil cooler kit with grex sandwich plate and lines $250
Turbosmart vee bov with cooler pipe $200
Saber cooler with 90deg bends welded on there $200
Alternator just been recoed $100
New starter $100
Turbo:
Gtx3076 twin scroll .82
6boost exh manifold ceremic coated
2x tial 38mm mvs
scremers cermic coated
3.5inch stanless dump pipe heat wraped
front cooler pipe with dash 4 nipples
all the braided lines oil, water, vacum etc
4inch inducer pipe with filter
selling this as a kit $4300 firm this only done 2track days and was fitted from hypertune
Exh:
3.5inch exh from dump on wards into twin 3.5inch tips, also comes with a rear muffler with twin 3.5inch tips $1000
Fabrication:
Catch can $400
water resiviour $350
D1 header tank $50
Powersteer resiviour $250
Fuel:
Expurt 1000cc inj and twin entry rail $700
turbosmart 2000 reg $200
2x bosch 044 $150 each
Surge tank $400
Electrical:
Vipec v88 $2000
M&W pro 16 cdi with 6 bosch coils on a neat alloy bracket and magnacore leads $1600
e-boost 2 black $400
Interior:
Bride copies but on genuine rails $500 each
Genuine TAKATA harness valid upto 2015 $350 each
D1 spec quick realese $40
Shell:
1993 180sx with old rego papers and tags
not rolling comes with genuine uras kit, dmax front and rear gaurds and bonnet
s15dash and gauges all wiring
custom cage
bigger tunnel
raised floor section for exh
tubs
removable front end
seam welded
dash green inside black outside.
it hard to describe the shell you have to look at it, its all quality this wasnt sprayed or fab work done in a backyard, this shell has 30k spent on it.
after $9k
all these parts on the car are new and less then 1000ks old located in castle hill 0407008651, i havnt stripped car yet but will start next week
https://www.sau.com.au/forums/topic/404106-stripping-my-rb26-180sx/
Possibly keen on cdi setup. Does it come with everything needed to drop straight into RB26 car, or will additional wiring be needed?
you will still need to modify wiring a bit, but comes with everything to work loom, coils bracket leads etc
oil cooler kit, all fabrication, interior, gtr rear end, 1 044, surge tank, injectors and rail, reg starter sold
also i think the turbo kit will suit rb20 and 25 by the look of the flange, has more wholes suits 25 by the looks of it, ill ask 6boost to confirm
That's crazy! Be sad to see it all pulled apart and sold off.
Free bump though, great bloke to buy off as I bought his old Precision turbo and manifold. Very helpful. Best of luck
Hey mate thanks.
THIS FOR SALE THREAD IS CLOSED, LOT OF THESE PARTS ARNT AVAILABLE AND SOME PRICES HAVE BEEN REVISED....HERES THE NEW THREAD http://www.skylinesaustralia.com/forums/topic/404424-r34-nur-rb26-gtx3076-s14-s15-cusco-cage-deep-dish-bnheaps-of-stuff/
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
