Hi everyone
Just happened today - I moved the stag early this morning out from the garage no issue- got back home this Arvo to move it back the stag won't start it's revving but just won't go, it's like it's chocking thats the way I will describe it. Even applying gas when starting just revs that sounded its chocking and won't go.
Any thoughts? Or this happened to anyone?
Thanks
https://www.sau.com.au/forums/topic/404115-m35-wont-start/
May have fouled the plugs just moving it out and turning it off. Does it try to start, splutters and dies or just no kick whatsoever?
You may try to put a booster pack on the battery for a bit extra juice when cranking. But please note - the starters don't like being cranked for a long time. They heat up and burn out quick.
https://www.sau.com.au/forums/topic/404115-m35-wont-start/#findComment-6431978
Sounds like afm might be playing up. Disconnected it, if it idles and drives better under 2000 rpm id say you have found the issue.
Give it a clean with contact cleaner, if that's doesn't sort it, it may be time for a new afm.
https://www.sau.com.au/forums/topic/404115-m35-wont-start/#findComment-6431993
  • 1 year later...
I know this is a majorly old thread but need help were is this eccs fuse ??????????? i no the fuse in the engine next to bateery but what one is it ?? also is that what controls the fuel pump ??
My stagea would some times no start then would eventyaly start noow it wont start at all so i replaced the crank angle thinking it was that but well its not still wont start.
https://www.sau.com.au/forums/topic/404115-m35-wont-start/#findComment-7269145
Can be cam sensors, which are more important than crank sensors when it comes to the engine starting. Have you tried unplugging the crank sensor? It should still start if the cam sensors are ok.
Probably best you get it on a Consult 3 if possible, just to check for logged fault codes, before swapping out good sensors.
https://www.sau.com.au/forums/topic/404115-m35-wont-start/#findComment-7269175
Ahk i though wouldnt start with out crank angle Ive put brand new one in so its not that .If its the cam sensors i hope its only passenger as i cant get to the drivers one. Yea may have to open me pockets and take it to nissan I guess was trying to avoid it lol
https://www.sau.com.au/forums/topic/404115-m35-wont-start/#findComment-7269185
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
