Hi ladies and gents. My 2.8 BFOT build is coming down to the business end and im looking for a fuel pump to do what i want. BEFORE i get any of the bosch brigade, i do not want multiple pumps, i wanf ONE feed pump and ONE fuel pump, that is all. Ive looked at the weldon range and im impressed, but i was offered a Fuel Labs Prodigidy Digitally controlled full speed controlled fuel pump for a very reasonable price. Just looking for anyone who may have any experiences with fuel labs products.
Thanks in advance, Allan
https://www.sau.com.au/forums/topic/404129-fuel-lab-fuel-pumps/
Yes, 3 or 4 were sent back to the supplier from here recently. 2 of them failed on first fire up backing a car off the trailer.
My honest opinion - stay away
Others may have not had the same experience but when we get a series of failures all in a row, we start to ask questions. Fuel pump definitely must be one the best quality parts on your car
any suggestions as to what may suit my needs elite? Im going big as future plans may mean bigger turbo and head combo.
i currently have ID2000's and a nismo intank which will be used as the lift pump.
thanks in advance, Allan
I've use one fuel lab pump which was supplied by a customer. It worked okay but it also failed about 6months latter.
I use Weldon personally. Despite being noisey they get the job done.
If your using one of the large pumps I'd advise setting the surge tank up so the Weldon can create vacuum inside the surge and fill it up itself ( they are actually designed to draw fuel vertically up to 4ft)
I've found that when using a lift pump to feed the surge the weldon will create enough negative pressure to collapse the hose feeding the tank.
One -12 from surge to bottom of main tank.
One -12 from pump inlet to surge
All engine returns running back to main tank (to allow maximum vacuum inside the surge tank)
Has work perfectly on several circuit GTR's and national V8 taxis I've converted to E85.
I'm using one as a transfer pump, apparently its the only pump they could sell me that will suck up a hose. Its a weird shape to try and fit into a tank though.
Have you looked at the 416 Walbro's? They look the goods but I have been waiting for one for a month now. Perhaps the Nismo/Tomei are still the best option for GTR's?
what about pierberg pumps. Have heard good things but would like some experience with them
cheers, Allan
What would you like to know Alan. I have a pair of them feeding my 25/30 making 580 rwhp on E85.
Zero problems and quieter than other pumps.
Just about fitment, support, failures ect ect. Ive had plenty of bad luck on this car in the past so i am wanting to make sure i get it right
Dont know what to say other than they have been in the car for a year or 2 and I dont even think about them. I guess thats the best rap there is. Set and forget.
I have a pair of them mounted in the boot and they mount like any other cylindrical pump.
Totally happy with their performance to date.
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
