Pulling these off my R34 next week as im finally bolting all the goodies on. Located in Bunbury WA, happy to post at buyers expense. All prices ONO. Parts done 107k's
Stock Auto Radiator, was rodded out less then 20km's ago $100
Stock turbo with inlet and outlet snouts, never boosted over stock $275
Stock exhaust manifold $25
Stock Injectors $100
Stock AFM $75
Stock Airbox with inlet snout and K&N Panel filter $175
Stock intake pipe with 3" solid section $25
Stock cross over with BOV $25
Stock Engine cover with mounting bracket $50
Stock seats minus the bracket that bolts them to the floor, comes with the rails though, drivers side bolster is a little flat $150
Shadow BF boost guage, less then 3 months old $75
3" Mild Steel dump, front pipe $125
Can MMS pic's if really needed.
0419943997
Edited by msports180
Factory BOV sold on cross over pipe.
Radiator is pretty damaged with bent fins, still worked fine, may be good for the tanks $50
Stock 3 gauges in the centre console, not the pod, just the gauges, worked fine $100
Any chance of getting a picture of the drivers seat?
Yep will grab some 2moro.
Turbo, front pipe and engine cover sold pending payment.
Parts above have sold.
Also have a basically new apexi pod with bracket to suit R34 GTT, $149 from just jap, sell for $100
I still havnt got the pic's of the seats, new phone wont talk to my PC, so if anyone wants pic's of anything i can MMS.
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
