Hi all, just clearing out parts scattered in my garage.
1. R33-R34 (2WD & 4WD/S14/S15/C34C35 Silvia/Skyline/Laurel & Stagea (2WD & 4WD) Garage Miniz Camber Arms - less then 50km usage on them, not your typical chinese crap $140
2.S14/S15/R32/R33/R34/C33/C34/C35/Z32/A31/Y32/Y35 Silvia/Skyline/Ceffie/Laurel/Cima/Gloria/Stagea Garage Miniz Toe Arms (non hicas only) - less then 50km usage on them not your typical chinese crap $140
Paid $220 each for these awhile back.
http://www.garageminiz.com/parts.html
3. R34 GTR OEM Black Alloy fenders with OEM indicators - Paint is in excellent condition, stored in bubble wrap, never got around to fitting the, came off Chuey's sexy Z tune styled R34 GTR $450
4. R34 GTR Carbon Wing blade, needs custom alloy end plates in 2mm thickness to fit, alternatively you can shave the blade down 2mm on each side and use the OEM end plates, or run it without the end plates with a 2mm gap on each end but there will be no adjusitibility, brand new and no damage, in excellent condition
purchased from DOR134's group buy and no longer needed $90 FIRM
5. Defi style 60mm black face gauges - Boost/Oil Temp/Oil Pressure; only boost gauge has been used for a week then removed, others are brand new and all gauges still have protective plastic on front of gauge. some scratches on casing, exact functions real defi's for a fraction of the price $130 for all 3, otherwise $50 ea comes with a free sandwhich plate for oil sensor fittings! Suit RB's.
5a. MearCat.com.au dual gauge pod suit 52mm gauges, made from strong fibreglass$50 FIRM
RRP $99 + delivery & $5 per hole drilling
http://mearcat.com.au/
6. HKS/Earls oil cooler suit R34 GTT/R33 GTST w/ Thermostat - non relocation type
HKS thermostat/block fitting, Earls customer braided lines and core
fins are in good condition, no damage to core or lines/fittings, $250
7. Zeal Function Front coilovers suit R32/R33/R34 $70
springs alone cost more than this, they are well used, eye mount bushing is in good nick still, however shocks are near dead and will suit as a temp solution or to keep a car rolling
8. R33 GTST 5x1 rear half shafts > diff to Hub
looks like these but with a bit more surface rust $50
9. R32 GTR non brembo brake rotors, still some meat left and lots of surface rust due to being outside $20
10. Blitz DD Venturi BOV, comes with universal flange with hose fitting; held 18PSI fine, no front piece attachment $50
11. R33 GTS/GTST/GTR Carbon A pillar covers - stick on by 3m or sikaflex - your choice, has a minor chip in one, $40 FIRM
12. R34 GT/GTT/GTR carbon windshield/wind deflectors/rain deflectors - fit by 3m double sided tape and sikaflex for extra strength. has a small hairline crack in it, purchased from DOR134's group buy but no longer needed $50 FIRM
fitment pictures here:
http://www.skylinesa...ost__p__6292930
13. AVS Model 7 18x8.5 +38 (if i recall) pair of rims with thrashed tyres, sprayed black but no damage to rims and in good condition;
$150
looks like these;
Items are located in Sydney near Gladesville or Orange Grove, prices are ONO unless FIRM is stated and excludes postage!
Interstate buyers to pay for all postage costs.
this is all i can find atm, i will add more in the coming days as i uncover some stuff!
Thanks for looking,
Keen on oil cooler, just a few questions
What filter do you use for it because I know they are pretty tight to get in and out as it is?
Come with mounting brackets for the cooler?
Core size measurements so I can have a good look to mount it?
Freight to Adelaide?
Thanks
Edited by rb2534
Hey rb2534,
i have not actually fitted this to my car, however finding an oil filter to fit should not be too hard to find and i would assume it would fit OEM filter,
Height: 14cm
Length: 29cm
Dash 10 hose fittings;
approximately $20 to Adelaide,5000
Cheers!
EDIT: the AVS rims are 17x9 my bad! $100
got these 2x ford xr6 falcon wheels for skids/spares 17x8
$50
blitz bov
Interested in carbon blade and weathershields for the r34 gtr. Can you please email me pics [email protected]?
Thanks Adam.
Thanks Adam.
I'll send pics over shortly, cheers
Hi, Will take the R34 GTR fenders have sent you PM
Someone else has already contacted me and has first dibs, if sale falls through I will let you know ASAP. Cheers
R34 windshields, ZEAL coilovers and R34 GTR fenders all PENDING PAYMENT
reasonable offers welcome guys, worst i can say is No/
  • 4 weeks later...
EVERYTHING SOLD EXCEPT
blitz BOV
R33 GTST 5x1 rear half shafts > diff to Hub.
bump, these stuff need to go
**********$40**********
**********$50**********
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
