Hi all, just clearing out parts scattered in my garage.
1. R33-R34 (2WD & 4WD/S14/S15/C34C35 Silvia/Skyline/Laurel & Stagea (2WD & 4WD) Garage Miniz Camber Arms - less then 50km usage on them, not your typical chinese crap $140
2.S14/S15/R32/R33/R34/C33/C34/C35/Z32/A31/Y32/Y35 Silvia/Skyline/Ceffie/Laurel/Cima/Gloria/Stagea Garage Miniz Toe Arms (non hicas only) - less then 50km usage on them not your typical chinese crap $140
Paid $220 each for these awhile back.
http://www.garageminiz.com/parts.html
3. R34 GTR OEM Black Alloy fenders with OEM indicators - Paint is in excellent condition, stored in bubble wrap, never got around to fitting the, came off Chuey's sexy Z tune styled R34 GTR $450
4. R34 GTR Carbon Wing blade, needs custom alloy end plates in 2mm thickness to fit, alternatively you can shave the blade down 2mm on each side and use the OEM end plates, or run it without the end plates with a 2mm gap on each end but there will be no adjusitibility, brand new and no damage, in excellent condition
purchased from DOR134's group buy and no longer needed $90 FIRM
5. Defi style 60mm black face gauges - Boost/Oil Temp/Oil Pressure; only boost gauge has been used for a week then removed, others are brand new and all gauges still have protective plastic on front of gauge. some scratches on casing, exact functions real defi's for a fraction of the price $130 for all 3, otherwise $50 ea comes with a free sandwhich plate for oil sensor fittings! Suit RB's.
5a. MearCat.com.au dual gauge pod suit 52mm gauges, made from strong fibreglass$50 FIRM
RRP $99 + delivery & $5 per hole drilling
http://mearcat.com.au/
6. HKS/Earls oil cooler suit R34 GTT/R33 GTST w/ Thermostat - non relocation type
HKS thermostat/block fitting, Earls customer braided lines and core
fins are in good condition, no damage to core or lines/fittings, $250
7. Zeal Function Front coilovers suit R32/R33/R34 $70
springs alone cost more than this, they are well used, eye mount bushing is in good nick still, however shocks are near dead and will suit as a temp solution or to keep a car rolling
8. R33 GTST 5x1 rear half shafts > diff to Hub
looks like these but with a bit more surface rust $50
9. R32 GTR non brembo brake rotors, still some meat left and lots of surface rust due to being outside $20
10. Blitz DD Venturi BOV, comes with universal flange with hose fitting; held 18PSI fine, no front piece attachment $50
11. R33 GTS/GTST/GTR Carbon A pillar covers - stick on by 3m or sikaflex - your choice, has a minor chip in one, $40 FIRM
12. R34 GT/GTT/GTR carbon windshield/wind deflectors/rain deflectors - fit by 3m double sided tape and sikaflex for extra strength. has a small hairline crack in it, purchased from DOR134's group buy but no longer needed $50 FIRM
fitment pictures here:
http://www.skylinesa...ost__p__6292930
13. AVS Model 7 18x8.5 +38 (if i recall) pair of rims with thrashed tyres, sprayed black but no damage to rims and in good condition;
$150
looks like these;
Items are located in Sydney near Gladesville or Orange Grove, prices are ONO unless FIRM is stated and excludes postage!
Interstate buyers to pay for all postage costs.
this is all i can find atm, i will add more in the coming days as i uncover some stuff!
Thanks for looking,
Keen on oil cooler, just a few questions
What filter do you use for it because I know they are pretty tight to get in and out as it is?
Come with mounting brackets for the cooler?
Core size measurements so I can have a good look to mount it?
Freight to Adelaide?
Thanks
Edited by rb2534
Hey rb2534,
i have not actually fitted this to my car, however finding an oil filter to fit should not be too hard to find and i would assume it would fit OEM filter,
Height: 14cm
Length: 29cm
Dash 10 hose fittings;
approximately $20 to Adelaide,5000
Cheers!
EDIT: the AVS rims are 17x9 my bad! $100
got these 2x ford xr6 falcon wheels for skids/spares 17x8
$50
blitz bov
Interested in carbon blade and weathershields for the r34 gtr. Can you please email me pics [email protected]?
Thanks Adam.
Thanks Adam.
I'll send pics over shortly, cheers
Hi, Will take the R34 GTR fenders have sent you PM
Someone else has already contacted me and has first dibs, if sale falls through I will let you know ASAP. Cheers
R34 windshields, ZEAL coilovers and R34 GTR fenders all PENDING PAYMENT
reasonable offers welcome guys, worst i can say is No/
  • 4 weeks later...
EVERYTHING SOLD EXCEPT
blitz BOV
R33 GTST 5x1 rear half shafts > diff to Hub.
bump, these stuff need to go
**********$40**********
**********$50**********
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
    • That's just a gauge, with a certain amount of electronic damping, and no-one cares if it is timely-accurate. I'd hesitate to use it for an ECU MAP input without knowing that it was a nice signal. Responsive but smooth. Not laggy. Not lumpy.
    • Took the dirty BMW to an actual drag meet so I could do a legit full pass on a sticky enough track and had a quiet goal to try and beat my PB in the old R33 GTS25t The time to beat:  R33 on stock RB25, Internal gate GT3076R on stock manifold tuned to about 17psi on BP98 and running on drag tyres: F20 M135i with intake, dump pipe and MHD OTS Stage 1 tune on street tyres - didn't even drop the tyre pressure: Kinda similar, and kinda way different
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
