R33/r34 Part Clear Out! Sus Arms/suspension/carbon Blade/gtr Fenders/hks Oil Cooler/defi Style Gauges
Hi all, just clearing out parts scattered in my garage.
1. R33-R34 (2WD & 4WD/S14/S15/C34C35 Silvia/Skyline/Laurel & Stagea (2WD & 4WD) Garage Miniz Camber Arms - less then 50km usage on them, not your typical chinese crap $140
2.S14/S15/R32/R33/R34/C33/C34/C35/Z32/A31/Y32/Y35 Silvia/Skyline/Ceffie/Laurel/Cima/Gloria/Stagea Garage Miniz Toe Arms (non hicas only) - less then 50km usage on them not your typical chinese crap $140
Paid $220 each for these awhile back.
http://www.garageminiz.com/parts.html
3. R34 GTR OEM Black Alloy fenders with OEM indicators - Paint is in excellent condition, stored in bubble wrap, never got around to fitting the, came off Chuey's sexy Z tune styled R34 GTR $450
4. R34 GTR Carbon Wing blade, needs custom alloy end plates in 2mm thickness to fit, alternatively you can shave the blade down 2mm on each side and use the OEM end plates, or run it without the end plates with a 2mm gap on each end but there will be no adjusitibility, brand new and no damage, in excellent condition
purchased from DOR134's group buy and no longer needed $90 FIRM
5. Defi style 60mm black face gauges - Boost/Oil Temp/Oil Pressure; only boost gauge has been used for a week then removed, others are brand new and all gauges still have protective plastic on front of gauge. some scratches on casing, exact functions real defi's for a fraction of the price $130 for all 3, otherwise $50 ea comes with a free sandwhich plate for oil sensor fittings! Suit RB's.
5a. MearCat.com.au dual gauge pod suit 52mm gauges, made from strong fibreglass$50 FIRM
RRP $99 + delivery & $5 per hole drilling
http://mearcat.com.au/
6. HKS/Earls oil cooler suit R34 GTT/R33 GTST w/ Thermostat - non relocation type
HKS thermostat/block fitting, Earls customer braided lines and core
fins are in good condition, no damage to core or lines/fittings, $250
7. Zeal Function Front coilovers suit R32/R33/R34 $70
springs alone cost more than this, they are well used, eye mount bushing is in good nick still, however shocks are near dead and will suit as a temp solution or to keep a car rolling
8. R33 GTST 5x1 rear half shafts > diff to Hub
looks like these but with a bit more surface rust $50
9. R32 GTR non brembo brake rotors, still some meat left and lots of surface rust due to being outside $20
10. Blitz DD Venturi BOV, comes with universal flange with hose fitting; held 18PSI fine, no front piece attachment $50
11. R33 GTS/GTST/GTR Carbon A pillar covers - stick on by 3m or sikaflex - your choice, has a minor chip in one, $40 FIRM
12. R34 GT/GTT/GTR carbon windshield/wind deflectors/rain deflectors - fit by 3m double sided tape and sikaflex for extra strength. has a small hairline crack in it, purchased from DOR134's group buy but no longer needed $50 FIRM
fitment pictures here:
http://www.skylinesa...ost__p__6292930
13. AVS Model 7 18x8.5 +38 (if i recall) pair of rims with thrashed tyres, sprayed black but no damage to rims and in good condition;
$150
looks like these;
Items are located in Sydney near Gladesville or Orange Grove, prices are ONO unless FIRM is stated and excludes postage!
Interstate buyers to pay for all postage costs.
this is all i can find atm, i will add more in the coming days as i uncover some stuff!
Thanks for looking,
Keen on oil cooler, just a few questions
What filter do you use for it because I know they are pretty tight to get in and out as it is?
Come with mounting brackets for the cooler?
Core size measurements so I can have a good look to mount it?
Freight to Adelaide?
Thanks
Edited by rb2534
Hey rb2534,
i have not actually fitted this to my car, however finding an oil filter to fit should not be too hard to find and i would assume it would fit OEM filter,
Height: 14cm
Length: 29cm
Dash 10 hose fittings;
approximately $20 to Adelaide,5000
Cheers!
EDIT: the AVS rims are 17x9 my bad! $100
got these 2x ford xr6 falcon wheels for skids/spares 17x8
$50
blitz bov
Interested in carbon blade and weathershields for the r34 gtr. Can you please email me pics [email protected]?
Thanks Adam.
I'll send pics over shortly, cheers
Hi, Will take the R34 GTR fenders have sent you PM
Someone else has already contacted me and has first dibs, if sale falls through I will let you know ASAP. Cheers
  • 4 weeks later...
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
