Hi everyone thought I'd wright up my project 33
It's only going to be used for drift and track
So far The mods are
Engine:
Gt35/40 .63
6boost
50mm pro gate
Greddy plenum (original)
750cc injectors
Vh45 tb
Hybrid fmic
Alloy radiator
Microtech lt12s
Spitfire coilpacks
Suspention:
Tein ha coilovers
Adjustable
rear lower arms,
front lower arms,
Camber arms,
Rear toe arms
Hicas lock bar
And now I've just touched up the body and put a new front bar on
It's got a mixed matched bodykit but looks ok still
My plans are now to flare out the rear guards to suit some 17x10 +15 d1r's as I've got them on the front with wide guards and I think it will make the whole car look sexy
Then in near future il start looking for ideas on rollcages I'm pretty set on trackart cages ATM
Then build a rb27 or 3025
Few pics so far
https://www.sau.com.au/forums/topic/404178-hixis-r33-drifttrack-project/
Forgot to add that I fitted some rb26 covers that will hopefully let it breath a little better
Thinking about ideas on a return to sump catch can but where to put it and how there built in a way that they don't contaminate
I'm still unsure about
No idea Doesn't have any gauges so I'm only guessing the boost
The setup used to make 280 on 15psi with a 82 housing
I'm only wanting 300 safely unill the engines built
Thinking if using an exhaust cam
On the inlet and see if that makes a difference for now , and il just give it a quick dyno run to make sure everything's running well
I'm unsure what brand they are I baught them off abe2 who is a well known sau member and good bloke I might add
All I know is they used to be orange and there wide haha I can find out if u like though
No more work on the old 33 today as I was busy doing other bits and pieces just gave it a good degrease and wash
And and and ... I picked up a rb30 engine today so now I can spend my Nights researching rb25/30 builds oh the joy!
Sounds good mate, but your gonna find that diff pretty shit for drifting...,
I shimmed mine up till it almost couldn't fit back in the housing, was mad for a couple of weeks, but after that it just opened up again.
They might last longer on the street, but on the track they die pretty quick.
At the moment mines got a weldy in it to get me out of trouble until I can get my 2way sorted, and it is heaps better than shimming it... Just weld that sukka.
Wel see how it goes with the diff hopefully it will last a little bit as I want to
Focus on other bits
As for the guards il send Abe a pm for you
It absolutely pissed down with rain yesterday so I thought what a great day to pull down some old motors and get the base parts I wanted for my engine, now I just have to source the rest of the parts that il need (I've been told spool do a kit that's pretty well the best value for money)
If any of u guys know any other places that are cheap let me know :)
Rb25 head
Rb30 block
That's BS.... Save yourself a HEAP of money and build the 30. Honestly you'll need the extra grunt in that boat.
You have to buy a billet crank to go rb28 anyway????? If your going that far buy the rb32 kit form Nitto.
Just keep it simple.... so when it goes bang, you won't feel so bad.
Leave the head alone, throw a set of rods and pistons at a 30 block, get a decent oil pump and sump.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
