Hixi's R33 Drift/track Project
Hi everyone thought I'd wright up my project 33
It's only going to be used for drift and track
So far The mods are
Engine:
Gt35/40 .63
6boost
50mm pro gate
Greddy plenum (original)
750cc injectors
Vh45 tb
Hybrid fmic
Alloy radiator
Microtech lt12s
Spitfire coilpacks
Suspention:
Tein ha coilovers
Adjustable
rear lower arms,
front lower arms,
Camber arms,
Rear toe arms
Hicas lock bar
And now I've just touched up the body and put a new front bar on
It's got a mixed matched bodykit but looks ok still
My plans are now to flare out the rear guards to suit some 17x10 +15 d1r's as I've got them on the front with wide guards and I think it will make the whole car look sexy
Then in near future il start looking for ideas on rollcages I'm pretty set on trackart cages ATM
Then build a rb27 or 3025
Few pics so far
Forgot to add that I fitted some rb26 covers that will hopefully let it breath a little better
Thinking about ideas on a return to sump catch can but where to put it and how there built in a way that they don't contaminate
I'm still unsure about
No idea Doesn't have any gauges so I'm only guessing the boost
The setup used to make 280 on 15psi with a 82 housing
I'm only wanting 300 safely unill the engines built
Thinking if using an exhaust cam
On the inlet and see if that makes a difference for now , and il just give it a quick dyno run to make sure everything's running well
Got progress done this weekend
Got the surge tank and Bosch 044 installed
Had the LSD diff shimmed upped to locked
And got the exhaust how I want it , stainless dump
And screamer and then mild to a megaflow cannon
I'm unsure what brand they are I baught them off abe2 who is a well known sau member and good bloke I might add
All I know is they used to be orange and there wide haha I can find out if u like though
No more work on the old 33 today as I was busy doing other bits and pieces just gave it a good degrease and wash
And and and ... I picked up a rb30 engine today so now I can spend my Nights researching rb25/30 builds oh the joy!
Sounds good mate, but your gonna find that diff pretty shit for drifting...,
I shimmed mine up till it almost couldn't fit back in the housing, was mad for a couple of weeks, but after that it just opened up again.
They might last longer on the street, but on the track they die pretty quick.
At the moment mines got a weldy in it to get me out of trouble until I can get my 2way sorted, and it is heaps better than shimming it... Just weld that sukka.
Wel see how it goes with the diff hopefully it will last a little bit as I want to
Focus on other bits
As for the guards il send Abe a pm for you
It absolutely pissed down with rain yesterday so I thought what a great day to pull down some old motors and get the base parts I wanted for my engine, now I just have to source the rest of the parts that il need (I've been told spool do a kit that's pretty well the best value for money)
If any of u guys know any other places that are cheap let me know :)
Rb25 head
Rb30 block
That's BS.... Save yourself a HEAP of money and build the 30. Honestly you'll need the extra grunt in that boat.
You have to buy a billet crank to go rb28 anyway????? If your going that far buy the rb32 kit form Nitto.
Just keep it simple.... so when it goes bang, you won't feel so bad.
Leave the head alone, throw a set of rods and pistons at a 30 block, get a decent oil pump and sump.
 Share
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
